Question about Philips 9P5544C 55" Rear Projection Television
Screen is blurry alot of orange and green halow. Low definition
I want to know where to start fixing this. Could it be a fuse for a circuit or is there a kit to fix it. Also I do not have the remote control for this tv will i need it to fix or can I use a universal remote?
  • rustysautone Nov 13, 2008
    basically my picture seems as though maybe some of the colors are either not working or to dim.when watching a movie that has a lot of dark sens,you just can not make it out enough to get the correct image.i compared watching a movie called the cave an on my PhillipsMagnavox i though there where a lot of sens that where suppose to be very dark,but not unvisitable.so i watch the same movie on another set and it looked to be a completely different movie.i hope i have given a description well enough to help you diagnose my T.V.correctly.i have had this T.V. for about 7 years and it has been the best i have ever owned.if i can get the color right i will use it until it just won't work anymore.i can't imagine any of the new model's bringing me more pleasure than i get from this one.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiScreen is blurry alot of orange and green halow. - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
of a set that needs the fluid cScreen is blurry alot of orange and green halow. - 2c07611.png/>
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 15, 2009
I took it to the local TV shop and he replaced the crt cooling fluid. The picture looks new again.
Posted on Nov 13, 2008
Shivering screen
take a back up using dr fone recovery tool and restore your device
Apr 26, 2013 | Apple iPhone4 4G iPhone 4
Of the 3 wires that feed into the headlight bulbs on my 2000 F350, I need to know which is positive and which is ground
The BLACK wires are ground. The LIGHT GREEN/BLACK wires are your high beam circuits. Then the low beam circuits are DARK GREEN/ORANGE on the right side and DARK BLUE/WHITE on the left side.
Jun 19, 2011 | 2001 Ford F350 Super Duty SuperCab
Fuji ax 280 out of focus and blurry on startup switch off and back on again its fine any help please.
Just tap on the sides of camera when you switch on it . There is definitely a loose contact between the screen and circuit board inside it . You confirm it to check that you are facing this problem due to bad connector . If you still face blurry on startup then it is due to faulty CCD sensor . You need to replce it ,but it will cost you alot in repairing it .
Hope this helps.
Please feel free to contact us if you have any further queries.
Shane
Feb 05, 2011 | Fuji Cameras
Diagnostic codes p1505 p1507 ran stalled wont run turns over fine
sorry but their are no diadnostic codes with this number in the manufacturers codes i have
P0505....Idle Control System
P0507....Idle Control System RPM Higher Than Expected
but i have found these generic codes for you if they help
Aug 10, 2010 | 2003 Hyundai Tiburon
7P5441 C101 54in color is wrong
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Rca projection tv is blurry
Hi, you need a tv tech, G2 focus block and pincushion circuit are what your describing, these are both related to the high voltage circuit but are 2 different circuits, definitely not a layperson repair, do yourself a favor and call a tech on this one, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Philips 9P5544C 55" Rear Projection Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
