Polaroid 4641-tlxb lcd tv. Black screen--no power. Won't turn off.
I have a 15-month old Polaroid 4641-TLXB, which has the following symptoms:
  1. TV screen won't turn on (red light will turn blue, but screen is blank)
  2. Can't turn off TV with remote or on the set (blue light won't turn red when the screen is blank); I have to unplug TV to turn it off
  3. TV also does not turn on when unplugged (even for a long period of time)then plugged back in.
I have seen the thread re the solution for the FLM-373B with identical problems. Would that approach possibly work for me? If so, I am a noob, so where would I find out which parts of the back to remove, where the offending capacitors are, and how to access them?
Alternatively, how do I find a reliable repairman in my area (just outside Philadelphia), given the fact that Polaroid is not a common tv. Polaroid is of no help (other than suggesting replacing the fuse, which I did). They won't recommend anyone. Although the Polaroid warranty has expired, I can get the credit card company to cover tthe costs, under their warranty extension program.
TIA.
  • 1 more comment
  • Anonymous Jan 15, 2009
    i had a similar problem with sony had to buy a new bulb just over a hundred dollars came in a pop in module. i searched for sony replacement bulb to find it. tv would not turn on . it fixed it the bulb lasts about 2 years
  • Freya216 Apr 29, 2009
    373b doesn't come on when turned on....get a flash of the Polaroid logo then black screen with the blue light. It will not turn off so I have to pull the plug to get it turned off. Just before this happened it developed a loud humming sound on the 1080i setting. We switched to 720 display and the sound problem lessened then the next thing that happened was the power failure when I turned it on.
  • pzip May 15, 2009
    Same problem, can't turn the tv on or off with the remote or the buttons on the side. I have to unplug the tv for a few seconds before I can turn it on. Also has developed a buzzing noise.
  • 749 Answers
SOURCE: Polaroid 4241-TLXB
here's your TV specifications and manual...
http://www.hdtvsolutions.com/flatscreen_spec.cfm?part_id=1948
http://www.hdtvsolutions.com/pdf/4241tlxb.pdf
Posted on Nov 26, 2007
  • 15 Answers
SOURCE: FLM-373B
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Jul 04, 2008
  • 3 Answers
SOURCE: 1511 TLXB used as PC Mon
You have to use the TV remote to access the set menu.
From there, you can set the TV to monitor mode.
Posted on Aug 25, 2008
albertv29
  • 87 Answers
SOURCE: Polaroid Model FLM-3232 Television
Most likley it is the main processor on the main board..You cannot replace this processor.Go to shopjimmy.com and see if they have just the main board.
Posted on Jan 12, 2009
rylee_smith
  • 8619 Answers
SOURCE: Polaroid 4641-TLXB LCD TV won't turn on
Hi!
First of all please unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino affect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem and for proper repair all the electronics must be diagnosed with the correct electronic test equipment and the correct skills to use the test equipment.
If you want to repair it yourself then you must be having an oscilloscope and has a knowledge to operate it.
If you decide this is not something that you can do it yourself then this repair will be about $100 to $300. If the problem is a bad circuit board, and if the board can be repaired or has to be replaced. A small TV repair shop will often charge less for the repair than a large electronics repair facility.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 24, 2009
When we run the satellite through a DVD player, the volume works fine. When we don't, we get bad static and popping. Dish Network has replaced the remote and the DVR, so it appears to be the TV.
I would assume the problem would be either in the cabling or the DVD player. Have you tried running thecable straight from th receiver to the tv?
Daniel Busa
DISH Network Customer Service
Jan 02, 2011 | Polaroid 4641-TLXB 46 in. LCD Television
Replacement remote for TV
The link below contains the replacement remote control for your unit.
Polaroid 4641-TLXB Replacement Remote Control
Feb 26, 2010 | Polaroid 4641-TLXB 46 in. LCD Television
Picture goes black
I had the same problem. Could you let me know how to replace the power supply? Thank you in advance.
Oct 18, 2009 | Polaroid 4011-TLXB LCD TV
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
Jul 05, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Tv will not turn on
i have the same problem. i just bought a powersupply but didnt change anything. i guess i will try lcd controller next?
Jun 13, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
VGA shut down
call Polariod
replace 'box'
(their description, not mine)
May 07, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Jun 17, 2008 | Polaroid 1511-TLXB 15.4 in. LCD Television
Televison & Video Logo
1,101 people viewed this question
Top Televison & Video Experts
