Question about Whirlpool Heating & Cooling
  • 31 Answers
Check wiring for condensor fan motor,make sure wire nuts and connections are tight,if still no luck then i'm afraid you have a bad condensor fan motor
Posted on Nov 16, 2008
Have an Amana air command 80 sse... and a HOT house! The AC comes on for a few minutes and then shuts off. The filter is clean... am wondering if there's a reset button. I have looked all around and...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know. Roger
Most condensing units have low pressure safety switches in them. If your system is low on refrigerant, the compressor will run a little and shut off. When the pressures across the compressor equalize, it will come back on. This cycle will repeat on till enough gas has leaked to stop resetting the pressure switch. If this is what is happening, shut the condenser off. Short cycling will over heat the compressor. You will need a technician to find and fix the leak. Also to recharge your system when repaired. Let me know if I failed to help. Roger
Apr 10, 2011 | Heating & Cooling
I have a 2 1/2 ton unit. If the outside temperature is 95 degrees. What should I expect from my unit in cooling my house.
If properly charged your unit should perform fine, having a dirty condensor at that temperature can cause problems not easily recognized.
A well insulated house should be able to maintain a 20 degree temperature difference whether its summer
or winter. No Mechanical cooling or heating involved
for at least 6-8hrs if not more.
If it never cools when it is 95 degrees outside the ambient outside temperature is not the problem.
At 95 degree out side air you should be seeing inside discharge air temperatures betwenn 48-55 degrees.
It is the load in the house that determines how long the unit will run at 95 degress.
Jun 21, 2010 | Goodman CKL24AR24 Air Conditioner
Central air Goodman ck30-1a blowing fuses?
I don't know what you use to heat your house, (heat pump, gas, oil) but if it is not a heat pump, i.e.. you don't use the outdoor unit to produce both heat and cooling, then the first place to look is at the compressor in the condensing unit (outdoor unit). If you have a bad capacitor, it will cause the compressor to pull locked rotor amperage (LRA) for an extended period of time and will cause the fuse to trip (usually within 2 or 3 seconds) The other possibility would be that something got into the wiring and have created a short. I have seen more insect and rodent damage to wires then you can imagine, so this is also a high possibility. Hope this helps
Apr 03, 2010 | Heating & Cooling
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Jun 14, 2008 | Kenmore 72055 Air Conditioner
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
205 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
