Question about Lands Phones
Need help can you explain to me please how to change ring tones in a ease way step by step and turn higher volumen?
    President:
  • 1,952 Answers
Menu<settings<tones
Posted on Nov 08, 2008
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Lands Phones
Need louder ring tone and how do I retrieve messages.
There was an app to increase speaker volume, "DSP-based equalizer" but it had to be built into the build as I recall. I tried it before on one of the Desire builds, and I can't say it was useful.
Aug 20, 2013 | Pantech Ease P2020 AT&T
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
I have a Nokia E51, which has a theme song for incoming ring tone and I would like to remove it for the normal ring tone, can you help? Cheers Daryl
HERE IS THE STEP BY STEP GUIDE TO CHANGE RINGTONE FOR NOKIA E52.
STEP#1. ON YOUR FIRST MENU GOTO PROFILE SECTION.
STEP#2.SELECT THE PROFILE YOU USE MOST.
STEP#3.CLICK ON IT AND SELECT OPTION CUSTOMISE PROFILE.
STEP#4.SELECT RINGTONE OPTION.
IT WILL SHOW YOU ALL AVILABLE RINGTONE SELECT THE ONE YOU LIKE MOST.
NOW YOU DONE.
Jan 26, 2011 | Cell Phones
My office phone have a problem when customer call always complain i dont pick the phone but the problem is i dont hear the ringing tone please help
You can find detailed information about your phone from the given link below.
Panasonic KX-T7730
Check the steps below for "Does not Ring" solution.
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | Panasonic KX-T7730 Corded Phone
I need to know if the cell phone, the pantech ease has built in ring tones and how to get to them??
Oh the Ease does have built-in ringtones! Just go to..
1. MENU- MY STUFF- AUDIO- then ansawer tones or ringtones. (for calling only!)
FOR MESSAGING RINGTONES TAKE THESE STEPS:
1. MENU- SETTINGS- PROFILES- NORMAL- MESSAGE- figure the rest out! LOL HOPE THIS HELPED!!!!!!!!!!!!!!!
Oct 19, 2010 | Audio Players & Recorders
How can i activate my ringtone
hi....
please follow these steps to activate you ring tone.
1.open menu--->profile---->select the profile which you are using currently
2.After selecting the profile---->select personalise from it.
3.there is an option in it,Incoming call alert
4.In that you have to select ringing to activate the ring tone.
5.There is an option called as Ringing tone,you can select which ever ring tone you want and save the changes.
thanx
Jul 18, 2010 | Nokia N73 Cellular Phone
How to turn the music off when a call come in.
More information is needed.....But, it sounds like you are trying to turn off/change the ring tone of an incoming call. It's easy to do, I left you a download link for the manual below.
Here are the steps to change your ring tone:
1. Leave the hand-set on the cradle
2. Now just press the flash key repeatedly to scroll through all the different ring tones or to turn it off.
If you need the manual for future reference, you can download it from the link below -- It was made and uploaded by me, so it is safe....
http://www.megaupload.com/?d=8EIJ8RH3
Hope this helps --WICC--
Jan 24, 2010 | Innovage 1604007 Corded Phone
I cannot find how to change the sms alert sound. I can change the ring tone.
I found a user manual posted on the net for my phone that Explained the steps to follow. Thankyou for your help.
Kind Regards
Gordon.
May 18, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Change msg tone to a customized tone
use a program called bitpim and get the usb driver for the "tu500" its the same phone but its just an Australian region phone item name and then you can change the internal sounds on the phone like message tones and all that and get rid of the annoying confirmation sound. if you need more help with this try googling "LG cu500 forums" you should get an lg forum website with ppl that have that problem and they list the steps there cuz that how i did mean how that helps
Nov 06, 2007 | LG CU500 Cellular Phone
Lands Phones Logo
199 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
