Our canon i9900 printer keeps putting blach smudged parallel lines on the white non printed back areas of greeting cards we are printing. How do we get rid of these?
  • zorie Nov 08, 2008
    I got the advise to clean the printer but what I really NEED is HOW exactly to clean the printer where the smudges appear. I understand that some ink rubbing is happening I just don't know the proper procedure. It appears that it is smudging as it comes out of the printer-- on the back side mostly but I can't see where the smudge issue is coming from. Please advise... I am sure this is a common problem and I love this printer. So hopefully you can help me. Dan
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Have you replaced the toner cartridge since 95% of image issues are caused by bad toner cartridges.
1. Take the paper out of the printer.
2. Turn the printer on.
3. With the printer on, hold down the form feed button (the other button, there are only two: power and the form feed) and watch the status light.
4. When the status light has blinked three times, let go. The printer will make some noise and attempt to feed paper and it will keep doing this cycle 4-5 times. When it’s done you can put paper back in and print.
I did this maintenance routine one time and reprinted the tendrils that were smudging and they turned out perfectly. I printed 4 copies and each one was perfect.
I don’t think there’s any downside to doing this cleaning routine, it uses no ink like a head cleaning does so I plan to do it after any long printing session just to keep the rollers clean.
thanks
goodluck
Posted on Nov 08, 2008
    Brigadier General:
  • 3,614 Answers
You should follow the printer maintenace wizard on how you will clean the print head. thhis utility always come when you install the printer driver.
    Master:
  • 763 Answers
Sir you can try printing a thick paper (not so thick) to remove the smudges and do this repeatedly until the smudges are gone. Also look for your software of printer and see the calibrate option. check also the cartridge if connected properly.
thank you for using fixya
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Nov 08, 2008
    have you tried bubble jet utility software? On that software there is a way you can eliminate smudges and perform some utilities on your printer. Can you look that on your CD software camed with your printer? I believe that is included if not then i will find one for you.
    CHARCOIS
    try this color calibration utility
    http://www.canon.ca/sd_busdrivers/buzdri...
  • 1,879 Answers
Do a test print on a regular paper to see if the lines show up, if it doesn't - card used is either too thick or wide.
locate the area where the lines came and swab it.
  • monk3ybidzness
    monk3ybidzness Nov 08, 2008
    card comes out face up - depending on "how you flip" the card will give you the idea where the lines of ink originates.
    confused ? swab both sides where the paper is moving and up to where you can stick your hands into.
  • monk3ybidzness
    look closer and closer where the paper moves - you wont get lost, theres only one lane where the paper moves.
    Sergeant:
    Novelist:
  • 196 Answers
The area from where the paper comes out has the ink leak there and it needs cleaning to avoid these problem.
  • mmechanics Nov 08, 2008
    the ink leaks in that area and get dried after sometime and become stiff at some part of that area .so when ever the paper passes through that area the stuck ink touches the paper and gives that strips on the back side of the paper.
    in the area from where the printout comes.just lift the printer cover and u can see the area from where the paper exactly comes out when you give the printout.the area is black in colour and the length of that black area is near to 12"inches.and there are small steel like fittings in that area.you ust have to clean that area of steel and also the sides of that steel area.u can clean it with isoprophyll and tissue paper.just OFF the printer and then take some isoprorhyll in the tissue and rub the wet tissue on that area properly.
    if this does not helps the printer needs to be opened and that cleaned part by part.
    taking it to the repair center is much advisable.as your printer is absolutely ok.and just needs servicing it will not be to costly.
I get lines on paper when printing on canon ir3025
I had somewhat the same issue with my Canon i9900. In fact it took THREE tries before I got it working correctly. On the first printer the ink carrier would never move. Canon sent a new printer right away. It worked about a week, then everything went red. I called and also talked with the service rep. Like you, they insisted I load the goofy Easy Print software instead of printing from Photoshop. Trouble is, Easy Print only works with Jpegs. Well, anyway, I did it, and of course it made no difference. So the rep felt it was a bad print head, (which is replaceable on the i9900. They sent me out TWO new heads, I replaced it, and it did fix the problem. I have used the printer for a few years now, but just once in a while I will get some lines, or more like smudges. A cleaning cycle usually takes care of it. I still have another new head if it ever gets too bad. I don't know if the print head is replaceable on your model or not, but it might be a place to start. Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Canon ImageRunner 3025 | IR3025 |
I want to ask if there is way to print someting on greeting card, wiyh the canon PC860?
no,
there is no way to print on greeting card.
use century paper to print then make greeting card.
Nov 04, 2011 | Canon PC-860 Black and White Copier
Vertical fine lines...
Don't have any idea but you might try this link. They have repair manual you can download.
http://printer1.blogspot.com/2009/01/canon-i9900-service-manual.html
It may be in the hardware and if it is you are talking a new control board. Does it print these lines if you print a self test page? If not you might try reinstalling the drivers. You might try different quality modes and see if that has a effect.
Hope some of this helps
Sep 01, 2009 | Canon i9900 InkJet Photo Printer
How to change print head on canon i9900
It is held in by a retaining lever on the top of the transport carriage. It is the lighter gray plastic piece on top. Follow it horizontally across to the right and the level to flip it up is on the right side of the transport towards the top. Just grab it and flip it up and then remove the print head assembly.
Dec 19, 2008 | Canon i9900 InkJet Photo Printer
I have a cannon i9900, it has always worked perfectly. For the past week I can not print anything. I reinstalled software today still down, I see one green light followed by 5 yellow flashes (keeps...
Dear Bill,
Flashing 5 times in orange indicates that print head error occurs so it cannot be detected properly by the printer. To make it sure, install a good print head in the printer. Is the problem fixed?. If the problem still persist, carriage part may be faulty. Overall, the print head is the most faulty part in this case. So, you need to replace the print head with new one.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Cannon Office Equipment & Supplies
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
Mar 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
jasbo
jasbo
