Question about Sony Handycam CCD-TRV318 Camcorder
Poblem with camcorder
C:31:23 constantly shows on LCD screen with eject sign. Can you tell me the possible proble and tapes previously played in the camcorder are now unable to play at all
  • 5 more comments
  • keify Nov 10, 2007
    When i go to record the eject symbol appears and it blinks C:31:22
  • llwlaura Dec 06, 2007
  • vgontier Dec 06, 2007
    wont play back recorded video, blinks C31:23 and beeps with eject sign
  • Kodandapani May 18, 2008
    As soon as i switch on camcorder, i am getting C 31:22 error.
  • lunoti3 Jul 05, 2008
  • vhill1 Jul 22, 2008
    I'm having the same issue with the eject icon coming on. I found that when the DC adapter is plugged in there seems to be no problem. Could it be a bad battery or low charge?
  • Anonymous Apr 18, 2009
    31:22
I had the same code. so i went to the sony web site and thier is a reset function i tried and it works so far . first i toke the battery out then went to camara mode held the red button for 15 sec then put the battery back in . so far so good .go t0 sony web site and look for troubleshooting for your model
Posted on Apr 07, 2009
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
When the cam is put on recordning mode a error on the screen shows the following- eject sign followed by ...D , On top on screen its written EJECT LP
The error display shows that the camcorder has some mechanical fault.Follow the instructions below.
1. Eject the Tape
2. Set to OFF
3. Detach the battery
4. Reattach the battery
5. Power ON as usual
Simple faults will be recovered when performing the above procedure.Good Luck
Jun 04, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I have a JVC video camera modelGR-D290U. I can play and view tapes previously recorded.But when loading a new blank tape the screen does not show what is being recorded and remains blank when rewinding and...
Sounds as though the imager may have failed but make sure you are in video postion instead of memory mode. Little switch behind the lcd screen. Larry's Electronics
Apr 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
Oct 21, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Jvc-super vhsc-wont do anything
if there are no missing parts ? you will get it back in approximately 10 days . . . the repairs will not exceed $ 50 ( plus shipping to and from puerto rico - zip 00794 )
Aug 03, 2007 | JVC GR-SXM755 Camcorder
I need Handy Help!!
The only thing I can find on this (and its silly sounding I know) is the following: 1) Moisture condesnation build up, leave the door open for 1 hour or more 2) The tapes you are using have write protection enabled
Jul 28, 2007 | Sony Handycam CCD-TRV37 Camcorder
Constant Eject Tape iluminated on screen.
Are there any error codes listed? Usually when a camcorder constantly ejects the tape it is because of a fault being present, the most likely one is moisture. Leave unit in a dry environment for a day with the cassette door open then try it. If you are sure the unit does not have moisture in it you probably have a bad moisture sensor. They go bad frequently. It is the small square device usually located on the deck base near the video drum and sometimes on the base of the drum. I do not know if you are capable of replacing this unit. If not you will need to find a reputable repair facility to get an estimate. Keep in mind from the description you gave of the problem it could be about anything. This is just the most common problem for this symptom. Several websites which offer free estimates are: http://www.videotech.com or http://www.camcorderrepair.com or http://www.videoonerepair.com Good luck.
Jun 15, 2006 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sony Handycam CCD-TRV318 Camcorder Logo
728 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
