Question about Belkin (F5D5231-4) Router
Belkin Wireless G Router F5D7230-4
The router is causing problem with my incoming and outgoing server. It is causing it to replicate emails. Also, causing system to run extremely slow.
  • Belkin Master
  • 4,338 Answers
This problems is due to the MTU (Maximum Transfer Unit) set in the router. I checked my Belkin and I could not find where to set it. It is usually under the advance tab in most routers.
I found a utility that will change it on the NIC card. Download and run DRTCP021.exe and set the MTU to 1452 if you have DSL or 1500 if you have cable. Set the MTU # in the MaxMTU box next to the NIC card shown.
http://www.dslreports.com/drtcp
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 23, 2008
Cannot access my e-mail or send
If you can connect to the Internet then the problem is most likely the configuration of your email client. You want to make sure you have the correct settings for your incoming and outgoing mail servers in your mail client. The Standard port used by POP3 is 110 for incoming mail, Outgoing SMTP server uses Port 25. Make sure your router doesn't have these ports blocked
Aug 13, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
Telkom email settings
No Outlook email password is different, without knowing the incoming and outgoing address is not possible to configure outlook, which email service are you using check with them for incoming and outgoing mail server address
Aug 09, 2014 | D-Link Computers & Internet
I am having problems with sending emails from microsoft outlook. I have been told there is a setting in the router that will fix this. Can you send me step-by-step instructions on where to go?
in the router... kindly provide more details about your setup. otherwise, all i know is that in your outlook, you should have the following set. username, email address, incoming and outgoing servers and a correct password for your account.
Oct 29, 2010 | Computers & Internet
Earthlink mailbox will not send/receive mail while connected to the Belkin F5D7234-4 ver 3 router.
First, you need to call earthlink and ask port numbers used for incoming and outgoing mail traffic.
Next, you need to call Belkin for assistance on how to open these ports on the router. The router's firewall prohibits access to some of the application ports.
Jul 31, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Incoming and outgoing servers
Well this totally depend upon email server that you are using. Generally it is pop server. For ports and server address you need to check this with the email service provider!!
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Send/Receive Error with Outlook 2002
What are the incoming pop3 & outgoing SMTP settings.they should be pop.sbcglobal.yahoo.com & smtp.sbcglobal.yahoo.com
Please check
Which antivirus are you using?
May 13, 2008 | Microsoft Outlook 2002 for PC
Email problems with a WiFi network using a BT 2wire 2700HG
because you have a third party email account you will have to go into the email accounts and in options look for my outgoing server requires authentication and tick the box. You may also need autorization from bt as they may not allow the incoming emails. also check that any antivirus programmes arent stopping the outgoing mail and putting them in the outbox.
Sep 06, 2007 | 2wire HomePortal 1800HG Router...
Emails
The default name server due to interaction with the router?s NAT firewall feature cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cant get my emails?!!!
The default name server due to interaction with the NAT firewall feature of the router cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D5230-4) Router
Belkin (F5D5231-4) Router Logo
368 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
