Question about Compaq Armada M700 Notebook
Compaq presario x1000 problem
1155 error: system board comm port address assignment conflict. 401 error. parallel port 1 address assignment conflict.
mi laptop no arranca, no setup cuando presiono F10, no run safe mode. no funciona.
en la web no se encuentramayor cosa.
gracias  laitux1
401-parallel port 1 address assignment conflict
uninstall all the parallel port and restart the system and re install them again and check again
Aug 29, 2013 | HP Compaq nx6125 Notebook
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
Parallel port will not power up print server.
May be your parallel port is disabled in BIOS setup.
Enter BIOS setup (DEL key on some common boards, F1, F2, F8 or even F10 on some branded machines) to enter BIOS setup.
Use arrow keys, Enter key and Escape key to navigate through settings.
If Parallel port is disabled, press 'Page Down' button or '+' button (only one might work) to get an address for the parallel port.
Save BIOS and exit. Restart the machine.
Tell us the result.
Aug 30, 2011 | Tally Genicom 3810S Printer
Window system error: there is an IP address conflict with another system on network?
The router to which you are connected is badly configured so th same IP has been issued to another pc. Either configure the router to assign the addresses in its network dynamically or manually assign yourself different addresses to every pc.
Jul 24, 2010 | Dell Inspiron™ 600M PC Notebook
Windows system error: "an IP address conflict wit...
This error indicates that you have two devices on your network that have the same ip address assigned to them.
If you have have ip addresses manually assigned to your network devices you can open a command prompt and enter IPCONFIG, this will tell you what the ip address is of the device that is giving you the error. This ip address is assigned to another device on your network.
You can either change the ip address of the device you are receiving the error from or find the device with the same ip address and change that one.
Alternatively, if you have a router that that has DHCP enabled you can change the properties on your network adapters to obtain the ip address automatically by going to Network Connections, right click on LAN connection and click properties.
May 21, 2010 | Computers & Internet
My toughbook says the comm port 1 is currently unable to connect
this is a conflict on ur board concerning the comm port 1, is either u reassign the port causing the conflict or call a techian to look into it. if wanna check this out go to start - program - accessories - system tools - system information. it will take some time b4 it displays and then select Hareware resouces then click on conflict sharing, IRQ 4 is ur COM1 port.
Jun 16, 2009 | Panasonic Toughbook 19 Laptop Convertible...
Disabling COMM ports
If you're pretty sure its your comm ports, boot up into your bios setup screen. (Tap Del while booting) Then go to the onboard devices page or any page that lists your com ports and change the property value to disabled.
Regards,
Worldvet
Jun 19, 2008 | EliteGroup K7VZA Motherboard
Boot
CORRUPTED BIOS Reprogramming the BIOS That depends on your motherboard Model. It should correspond to your BIOS Model. Download the Motherboard's BIOS file usually in a Zip file then the contents are .bin files. Then use the BIOS manufacturer's EPROM Programming tool. Which usually comes with a user manual or guide on how to's. Just follow its examples. Hope this helps ======================= If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Intel DG965WH Motherboard
System board comm fault
Sounds like an IRC Conflict with one of your devices. Go into your control panel , computer managment, device manager and see if any devices have an ! beside them and try to re-install the drivers for the affected piece of hardware. Make sure they have all the correct drivers installed. Have you installed any new hardware? what OS are you running? If you have installed new hardware into your machine, it could be a jumper issue. Have you checked your settings in the BIOS or modified any settings in there? You could also try to reset your BIOS back to factory default settings if you have been changing settings, that could also lead to your problems.More info is needed to help you further. Good Luck
May 08, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
