Question about Canon imageRUNNER C6800 Copier
Error code e000800-001
Canon image runner c6800 copier
  • 168 Answers
Not the fan open the front door pull out number one unit check the assymbly behind the frame it will move when you move the handle if its bent tou will get that code when you close the door
Posted on Dec 08, 2008
  • Canon Expert
  • 1,326 Answers
A E0800 code deals with a fan. It is either making noise and not getting to the right speed or it is frozen up or it is disconnected.
Posted on Nov 09, 2008
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
WHAT Cannon image runner 2525 ERROR CODE 000002
The main thermistor (TH1) has poor contact or open circuit. The thermal switch (TP1) has open circuit. The SSR is faulty. the DC controller is faulty.
The temperature of the fixing roller does not reach 100C with 2 min after it has exceeded 70C.
Apr 28, 2014 | Canon imageRUNNER C6800 Copier
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
I can't find the serial number on my canon 2270 Image Runner
when you press 123 button on right side of the lcd, you will be able to see counter and serial number.
Aug 05, 2010 | Canon imageRUNNER C6800 Copier
Color calibration
now you can do a full auto gradation under the additional functions button. just follow the instructions as you run it they are self explantory.
though my experience from working on them it is never that simple. there is so much involoved on the inside of this machine that will wear the toner starter out, the developers go bad, cleaning blades and several other factors all effect the color of this particular machine.
so start with the auto gradation and if that doesn't help then i would suggest getting a tech familure with that machine to come and fix it for you.
Apr 24, 2010 | Canon imageRUNNER C6800 Copier
Image runner 4570
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech... it might be very serious...
Dec 21, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon IR C6800 Error 00003-0042
According to Canon, this code is being thrown most likely because the fixer (fuser on Xerox copiers) is not seating properly inside the frame. Vibration coming from the copier operating is most likely jarring the wiring connector, making it work loose and causing the computer to throw this error code. There is a fix for this but unless you are a certified Canon Copier technician, it is highly recommended you contact Canon to send a tech to fix it. I hope this helps you.
Oct 07, 2009 | Canon imageRUNNER C6800 Copier
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
Cannon image runner c6800 error code E000001-0003
Its a fuser error and it has to be reset in service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
if the problem comes back there is a problem with the fuser but in my experiance resetting has worked 99% of the time
Mar 05, 2008 | Canon imageRUNNER C6800 Copier
Canon imageRUNNER C6800 Copier Logo
398 people viewed this question
old marine
old marine
