Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Brand New Incanto, Grinder Doesn't Work
We have just unpacked out Saeco Incanto Deluxe S Class and the grinder doesn't work. We filled the water reservoir and loaded beans into the machine, when we attempt to brew the coffee, it makes a "grinding" noise but the beans do not pass through the grinder and hot water is produced instead of coffee. I have a hard time believing that the grinding blades themselves could be missing as the machine is tested with coffee before it is shipped.
Any insight? Thanks for any suggestions you can offer!
  • jawind Jan 15, 2009
    Hi I have a similar problem with Saeco Incanto Sirus. The grinder grinds for a couple of seconds but then stops. No water is coming out but the machine and is ask for more coffee.
    Seems like the grinder can not grind the beans or that they block someting.
    Any advice?
    Jesper
  • 515 Answers
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Posted on Nov 08, 2008
Saeco Incanto Deluxe won't dispense coffee while it making a sound of brewing coffee
try to make pregroun coffee ,but without beans,just press pre groud button -if water comes out then yuor coffee beans are too fine- turn to hight number the grinder
Aug 21, 2013 | Saeco INCANTO DELUXE Espresso Machine
Removing finger guard and cleaning ceramic grinder in Saeco product
Before starting, find the parts diagram for the Incanto Deluxe (google search: "incanto deluxe" "parts diagram").
To remove the finger guard, first remove the silicon plug (part number 90 in parts diagram) in the center of the grind adjustment knob by poking an unbent paperclip with a small hook along the silicon plug's edge, twisting 90 degrees and pulling the plug out. Next unscrew the phillips head screw (part number 15) way down in the center of the adjustment knob and remove the knob. Then remove the phillips head screw (part number 120) holding the finger guard to the bean hopper.
I'm not sure how to work on the grinder, but from here at least you should be able to get to it. I suspect that simply removing the finger guard may make things a lot better.
Mar 14, 2012 | Saeco INCANTO DELUXE Espresso Machine
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
My Saeco Vienna Deluxe started to leak water underneath and the grinder will only grind coarse and not fine for good espresso, should I ditch this one or repair? I know Saeco is not good at customer...
hi i hope i can help you ? may i please ask you are you over filling? if not open the machine up and go straight to where the water is coming out check for a broken seal if the seal is ok check for any little hair line cracks
May 07, 2009 | Saeco Incanto Classic Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto "grinder blocked"
provide in detail about your problem ..........
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco incanto deluxe
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
Jun 10, 2008 | Saeco Incanto Classic Espresso Machine
No coffee coming out of the machine!
First step, increase the grinder size. Note: only change grinder setting while the grinder is spinning. If that does not work, look into cleaning your brew group screens. The machine should have came with a key to remove the screen. If your machine as a preground option try making a preground coffee without inserting coffee to see if only water will come out. If water comes out then you know its your grinder. Usually too small of grinder sizes will stop water flow.
If you need a brew group key:
http://cerinicoffee.com/Saeco_Brew_Group_key.asp
Espresso machine Cleaning supplies:
http://cerinicoffee.com/Coffee_cleaning_supplies.asp
Dec 01, 2007 | Saeco Incanto Classic Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
271 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
