Question about Xerox XA7-192i 19" LCD Monitor
Monitor comes on, shows the screen for a second then goes blank
The monitor is still getting power as they power light is still blue, I switch it off and then on again and it will show the screen for a second then goes blank. I'm using a different monitor on the same computer so it doesn't seem to be the graphics card.
  • alan dodds Nov 08, 2006
    Hi, its a manufacture problem, i tried this monitor on another computer and the same thing happened.
    Its still under warranty and i'm currently awaiting the new one being delivered.
    Thanks for your help.
  • cyanide4123 Nov 10, 2008
    Currently no solution. I was here to see if someone knew if this could be solved by downloading a new monitor. Graphics card works as I am using a monitor right now. Is there a selection to leave the analog and go to digital? I have a FPD1960 TFT LCD bought used.
I think it is down to ur existing monitor drivers if u unistall them and then go to ur manufacturing site for ur new monitor and download the drivers for ur monitor and then try taking ur existing monitor out and bye plugging ur new monitor in it should support the drivers and work trust me it should work i done it last night. hope it helps night!
Posted on Oct 07, 2008
You have a blown capacitor. I have a 19in Sceptor that did the same thing. I going to Radio Shack to buy the parts tommorrow. Should take about 30 minutes to de solder and re solder the new Capacitors.
Posted on Oct 13, 2007
Warranties and customer support Xerox have the worst reputation for customer services, I ignored this advice at my cost. Faulty goods= invoked my warranty after 6 weeks old, I have waited over 4 months for my replacement, yes they collected the faulty unit, and left me with no monitor or refund. Sick of phoning and emailing, having to take a legal route with them now, so be warned.
Posted on Mar 27, 2007
  • 56 Answers
The main problem is here is the graghics card its needs to updated and make sure the pins are alright on the display cable. Also you need to uninstall the integreated one that came with the PC first before you install a graghics card. so right now you need to put the display back to the motherboard display then when you have that done then you put it in the grafics card you have then it should something i had the same promblem for awile i couldnt figure it out either. Hope that works for you. Good luck
Posted on Nov 08, 2006
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Apr 16, 2009 | Computers & Internet
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Xerox XA7-192i 19" LCD Monitor Logo
267 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
