Integration of Cable Vonage and Wireless Router
Folks I need to get this new router to work with Mortorola Vonage VT2442 and Time Warner SB4220 with a Belkin G+mimo I've done this before and felt like putting all of it in a blender Any thoughts on this?
Beken did a great job on the hotline and configured the router to be an acess point.
Posted on Nov 09, 2008
I have Time Warner cable and use vonage. My set up is a D-Link Model: WWR-VR vonage router and an SMC8014W-G EZ connect wireless router provided from time warner. The cable internet is connected to the...
Welcome to Fixya. I would like to know the location of the wireless router and the wireless computer and the google tv. Are they in a same room, same floor? any walls or obstacles that can block the wireless signal? any other device that has the same issue with the router when put in a same room? Please provide the information needed to be able to fix the issue.
Sep 09, 2011 | Linksys Wireless-G Broadband Router
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Dec 18, 2009 | D-Link DIR-615 Wireless Router
I have the RCA DCM425C cable modem and also Vonage phone service. So my modem ethernet connects to my Vonage internet. I would like to go wireless in my house. How would I do this?
You would connect from the output of the Vonage modem to the wireless router and then from the wireless router you can connect Ethernet to your desktop if you have one and then anything else can run off of the wireless.
get a wireless router / cable modem combo provided by companies such as netgear then you would connect the Vonage to the router through one of the available Ethernet ports and any other Ethernet connections to the router as well and anything else wireless would work wireless.
Can you help me set up my home computer my time warner modem n vonage modem with my belkin router?
So you are trying to set up the router.
you can connect the router to the modem and the computer to the router.
Set up your router properly sothat your computer can go online through the router.
Pnce your computer is online through the router, then connect the Vonage to the router and it should work.
First make sure that your computer will be able to go online when connected directly to the Time Warner cable modem.
Click Here for step by step solution on how to set up router.
Nov 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Hooking up Vonage to Time Warner Roadrunner(dsl): Do I have to buy a Linksys Wireless device for my Vonage to work?
You just need a router. and then plug the vonage device onto the router.
Note: make sure you have internet with the router before pluggin the vonage device to it.
Aug 15, 2008 | Linksys Wireless-G Broadband Router
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
