posted by the bird on Oct 21, 2006
When I turn my TV on it starts up right, but then when the picture and audio come on it stops and does the same thing every minute or so and the display lights stay on.This problem happened a couple weeks ago and then it stopped and then just started again.
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 22, 2008
have same problem sony kdf-e60a20 cuts off picture sound power stays on
Best Solution
posted on Mar 30, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
try cleaning the bulb
dust build up will over heat the assembly and shut the picture and sound off
mine did the same thing and
now it works great like new
just follow the manual on taking the bulb out use air in a can too clean it
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony KDF-E60A20 60 in. HDTV LCD
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Sony KDF-E60A20 60 in. HDTV LCD Television
Unable to turn TV on
TV is stuck on Standby and will... Answer This...
Sony LCD Proj TV stuck on the...
My Sony KDF-E60A20 TV was... Answer This...
SONY LCD 60" widescreen
I have a 3 year old SONY... Answer This...
TV won't turn on and red light...
I've seen 4 and 5 times. What's... Answer This...
Thermal Fuse
Thermal Fuse
Did you use the Sony Service... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
