Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stopped and will not drain properly.
My 5 1/2 year old machine stopped and willnot drain properly.
About a monthe ago this happened and i cleared the white drain part and hoses under the machine.
Now it is stopping again so I unplugged the machine and started again, it starts and makes noises from the black part under the machine attached to the white draining part and does not drain, will not go on spin.
Do i need to replace this black part .... I think its the pump.....
Please let me know asap, I have 3 girls and going to the laundry mat cost me a small fortune yesterday.....maybe i should just buy the part and use my own machine.
Thanks,
Karina
  • kphilion Nov 09, 2008
    Thank you very much ...... I did check out the price for this part at an appliance part store in Barrie Ontario and they said it would cost $159.00 but I will check the places you suggested and price compare.
    Love this website.....You guys are amazing.
    I will go buy the part and see if that works.
    Thanks again,
    Karina
  • 5,911 Answers
The black part you mention is the drain pump motor. If the pump impeller is damaged, the motor may still run, but the pump will not drain any water. If the washer does not drain, it will not go into the final spin. The pump is sold as an entire assembly. Go to searspartsdirect.com and type in your COMPLETE model number. The pump will be listed under the "Pump and Motor Parts" heading as item number 10 (part #280187). This is not a standard part that an appliance repair center would normally carry in their inventory, so it would have to be ordered anyway. So...why not cut out the middle man? You can use other web sites for a cost comparison, but this is the cheapest place I have found it listed (use the part number listed above for your search)
If you need instructionson how to replace the pump, you can use this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 08, 2008
  • Jeff Rockwell
    Jeff Rockwell Nov 09, 2008
    Karina,
    Check with the website I mentioned to see if they ship internationally. This may save you quite a bit in the long run. Keep me posted if you need further assistance.
Intermittant 0E error
I believe the OE error is generated if it takes too long for the washing machine to drain. If the drain is blocked or the pump is is not functioning well, the error will show up intermittently. I believe we experienced a similar error a couple of years back. After verifying the drain was clear, I replaced the drain motor, I believe the washing machine was about 5 years old at that time.
Feb 28, 2013 | LG WM-2277HW Front Load Washer
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
My washer will not work in the spin and rinse cycle.
Whats happened is that the clutch/brake assembly is stuck.Without a qualified service tech. you can really get taken if the repairman doesn't know the trick to this.I can walk you through this step by step and you need only a 5/16 nut driver or socket.
Dec 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer stopped and will not drain ...... Shuts off
if there is nothing in pump replace it ,door will unlock when error code is fixed on 2nd person if its not your pump its your ccu board top rear ,to open door take off bottom panel 3 star screws put hand up inside under lid switch there is round plastic tab pull down while opening door its a release cloths "less soap plz "
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain - completely.
I have been having the exact same problem in a top load Kenmore 80, starting about a year ago when I replaced the pump because the old one, (30 years old), finally seized it's bearings.
The new pump design has some rough edges near the water exit port and lint slowly collects there until it stops it from draining properly. Since the lint clumps do move around a bit, when the problem first starts occurring it is an intermittent problem, but as more lint accumulates it gets worse and worse.
The old pump couldn't be taken apart, (and never need to be taken apart), but the new one can be disassembled rather easily and when the lint clumps are removed everything works great for another month or two.
The pump is the so called direct replacement from Sears, for the washing machine that they sell, but obviously is not well suited for machines like mine that do not have lint filters.
I suspect they want to render my machine obsolete so that I buy a new one, after all they don't make much money selling 1 washer every 30+ years, especially if it rarely needs service. Why else would they sell pumps that don't work in place of pumps that worked well and lasted over 20 years.
anamouse@earthlink.net
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
