Question about Nikon F100 35mm SLR Camera
Aperture priority not working...HELP!!
Hi, I have a Nikon F100 with an MB-15 grip/battery pack and a nikkor 70-200mm AF non d/g type lens also a nikkor 28-100mmG AF and a sigma 28-70mmD AF macro lens for Nikon. I have just realized that my aperture priority mode is not working...I've tried all 3 lenses. Shutter priority works fine, Program works fine and is adjusting the aperture as per metering...but when I select aperture priority, I am unable to change the aperture number up or down....PLEASE HELP ME AND MY CAMERA!!!...;-) Thanks for your time. Mike
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Posted on Sep 30, 2007
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Jun 12, 2016 | Nikon D Cameras
Nikon 24-120mm G ED VR
Could you confirm that this is a G lens (without an aperture ring)? If so, try cleaning the electrical contacts on the back of the lens and in the lens mount on the camera.
Dec 01, 2012 | Nikon AF-S Nikkor 24-120mm F4 G ED VR -...
What type of lenses fits this camera
Lens mount Nikon F mount (with AF coupling & AF contacts)
Lens compatibility • D-type / G-type AF Nikkor (except IX-Nikkor): Autofocus and all functions possible
• PC Micro-Nikkor 85mm f/2.8D: Usable in Manual exposure mode
• AF Nikkor other than D-type (except AF Nikkor for F3AF): All functions except 3D Matrix Metering possible
• AI-P Nikkor: All functions except 3D Matrix Metering and autofocus possible
• IX-Nikkor: Cannot be used
• Non-CPU: Usable in Manual exposure mode (exposure meter cannot be used)
Electronic Rangefinder usable with lens with maximum aperture of f/5.6 or faster.
Jul 04, 2011 | Fuji FinePix S2 Pro Digital Camera
Hi i purchased also Nikkor AF 50mm f/1.8D and i could'nt hear the click sound when i mounted it on my Nikon D90 cam, and return to my kit lens and it's doing very well. I did follow the advised you give...
You need to turn the aperture ring to its smallest aperture (f/22) and lock it using the little orange slide. Control the aperture from the camera, just as you do with the kit lens.
Nov 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
When i attatch my 70-300 lens i get a flashing FEE in the box,the book says to set the minimum aperture how do i do this please.
Thanks for the additional info.
First, an apology: I misread the lens description, sorry. If you have the "AF 70-300mm f/4-5.6 ED Nikkor" then the lens DOES have an aperture ring at the rear of the lens. If this is the case, then your D50 is compatible and all you need to do is turn the aperture ring on the lens until it's at the minimum f32 setting. The "FEE" message on your D50 should then vanish. When set this way, you control the aperture setting on the lens via the camera body controls. The command wheel alone adjusts the aperture when in Aperture Priority mode, and in Manual or Shutter Priority modes you need to first press the " /-" button behind and to the right of the shutter release before using the command wheel. There's even a handy little printed icon of a lens diaphragm to remind you of the secondary function of this button.
If your lens model is the "Nikon 70-300mm f/4-5.6G" then like a G lenses it lacks an aperture ring and so can only be controlled by Nikon bodies which operate the aperture from the body alone, like yours. So if you're getting the FEE error with a G lens then there's most likely a common fault which occurs with Nikon bodies with a small switch beside the lens mount. In the picture (courtesy and copyright of Digital Photography Review), the switch is at the 8 o'clock position.
This switch is activated either when a non-G lens aperture ring is turned to the smallest setting or when a G lens is correctly mounted. It is possible for the G lens to be damaged in such a way that the switch doesn't get activated but it's rare. If the switch is broken the camera body will need a repair.
Hope this answers your question, but if not add further comments. If it has answered your problem then please let me know by rating my reply.
Sep 14, 2010 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
ON DISPLY, APERTURE SHOW fEE AND DONT SHOOT
In all but aperture priority mode and manual modes you must set this lens to it's minimum aperture setting (i.e. highest number) to allow the camera body to fully control the aperture for you.
You'll also get this problem when using certain Nikon bodies which rely solely on electronic communication of the lens settings to the camera body (e.g. Nikon F75) as they lack the ability to read the mechanical linkages on the rear of the lens.
Oct 04, 2009 | Nikon Telephoto AF Micro Nikkor 60mm...
Blinking F-- on screen
The blinking f usually means you are in program or aperture priority mode and the f-stop ring has been unlocked and moved from it's maximum aperture or the lens contacts are dirty and not making a good connection.
Sep 20, 2009 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
AF not working on Nikon D80
release the lens at smallest aperture then reattach....
Jun 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Nikon F100 35mm SLR Camera Logo
229 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jay Plesset
Are you a Nikon Photography Expert? Answer questions, earn points and help others
