Question about Oster 5836 ExpressBake Bread Maker
Replace paddle I need to replace the paddle on my Oster bread machine. There is a clip on the bottom that needs to be removed and hopefully can be reused. I have the new paddle but it didn't come with a new clip.Anything special in doing it?
  • 1294 Answers
SOURCE: bread machine
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 22, 2007
SOURCE: Oster 5821 breadmaker
I had a paddle freeze on me too I took apart the lower end and lubricated it then put it back together
Posted on Apr 08, 2008
  • 368 Answers
SOURCE: oster bread machine 5811 manual
Hello waunellenune,
1) Here's the URL for their Breadmaker Manuals page:
If you can't download a version sufficiently close to what you have, I'd call Oster - - the Breadmaker 800# is800-438-0935 - - and ask about their recommendations.
If I can be of further assistance, let me know.
If this solves the issue, please rate it accordingly.
Thanks in-advance for using,
Posted on Jan 28, 2009
  • 368 Answers
SOURCE: Oster 5838 ExpressBake Bread Machine SPARE PART
Hi ka_haa,
Since you don't specify your location, some of what I'm offering may need adjustment, but generally you have the following options. What follows is for the USA.
1) Contact Oster - - the Breadmaker 800# is 800-438-0935 - - and ask about their recommendations for parts or repair. They will likely not want you doing electrical repairs yourself, and will probably refer you to a service center.
2) Check online auctions like eBay or
3) If finding parts is difficult, you might consider buying either
- a used machine for parts (again, online auction, and don't pay too much).
- a new machine and use your old one for parts.
I've used this strategy on both cars and computers - - often makes more sense than trying to hunt a single spare part when you need it.
You may download, save and print the .PDF manual free of charge from:
This .PDF document does not specify it as the Model 5811 manual; however, it is nearly identical, right down to the control panel on top.
Before I posted this comment, I downloaded, saved and printed the .PDF manual, and then took it downstairs to give it a whirl. PERFECT! At the time of this writing, my elderly Oster Bread Machine, Model 5811, #BM-100 (J222) is whipping up my first large loaf of white bread!
Incidentally, we discovered our Oster Bread Machine sitting on a shelf in an old house we were given as an apartment community manager quarters. It was sitting with some other stuff slated to be hauled to Goodwill (or the dump)!
I spent the past hour surfing the net looking for an Oster Bread Machine Model 5811 manual. Other than a couple of site where I was asked to pay a fee to download a .PDF or .ZIP file, there was little else. A couple of sites that purported to be THE place to download the manual turned out to be non-existent or otherwise dead ends.
Hope this helps all you who have been seeking this manual in vain for so long.
Happy Baking!
Posted on Jan 12, 2010
0 characters
1 Points
Bread keeps sticking to paddle. Tears a big chunk of bread out of bottom. Happens all the time. Any solutions, Thanks
You might need a new paddle if cleaning yours doesn't work. It needs its release coating. You could also try making sure the paddle moves smoothly on its shaft. If it hangs up when you pull the loaf out, it'll tear a big hole in the bottom of the loaf. Replacement paddles for most makes can be found on eBay. They run around $15, though, so I'd try cleaning and lubrication with vegetable oil first. Good luck.
Mar 04, 2011 | Oster 5838 ExpressBake Bread Maker
How do I remove the stirring paddle to replace it with a new one? I've tried pulling it out with a large pair of pliers
I'm sorry you used pliers. If it has the non-stick coating you may have damaged it.
I have posted a video on you tube of how to remove a severely stuck bread machine paddle.
Just go to you tube and type in ...How to remove a stuck bread machine paddle or kneading blade"
and you will see how to do it without damaging your paddle or pan.
Nov 20, 2010 | Oster 5838 ExpressBake Bread Maker
Who made the Regal bread machine? Possibly Sunbeam/Oster? I need a paddle and I think there are likely other machines out there with the same paddle.
Regal Ware bread machines were made by Regal Ware, Inc. in Kewaskum, Wisconsin, but they have not been manufactured since 1999. In the past 11 years we have depleted our stock of replacement parts; and paddles, drive belts, bread pans, etc. are no longer available. Our consumer service department advises that some consumers have had success in finding used parts on eBay.
Pat Seitz
Regal Ware, Inc.
Nov 03, 2010 | Regal Ware GL2850 Bread Maker
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
New Bread Maker, pan will not come out
The metal clips in my bread machine are just to hold it steady. You should pull the pan straight up.
When I take the loaf out of the pan after it has baked, I take the pan out and then set it on its side and wiggle the the thing on the bottom that makes the paddle turn loosen the paddle. Then I tip the pan over and holding the pan by the bottom and the handle, I dump the loaf out onto a kitchen towel to allow the bread to cool. It is recommended to allow the bread to cool for a few minutes for easier removal, but if the bread stays in the pan too long, it makes the crust soggy.
Mar 16, 2010 | Oster 5838 ExpressBake Bread Maker
I accidently threw out the paddle for my Breadman bread machine model TR555LC. Exactly which paddle is it that I need to purchase to replace it? And where can I find it? I found three replacement paddles...
Call the company - listed in your manual. Paddles are cheap and I always order an extra one. Have your model number ready. Also, if it is an Oster machine, Sunbeam is a subsidiary of Oster.
Jan 11, 2010 | Breadman TR555LC Bread Maker
The paddle will not stay in the machine and the water leaks out
The sealed bearing at the bottom of your bread pan has failed. There is no fix for it. You will need to hunt around for a new bread pan. Check ebay. (My pan failed also, and the pans on eBay were about $30.00. I bought a brand new Sunbeam at Walmart for just under $50.00. Oster and Sunbeam are the same). Good Luck...Hank
Dec 12, 2009 | Oster Breadmakers
Paddle won't turn
Although my Oster breadmaker is older (5811) it had the same problem (frozen paddle) and I just fixed it today. First read this article on maintenance:, then watch this video on disassembling a breadmaker: The good news is the bottom comes more easily than the video and the workings are easier. If your belt is fine (which mine was since Oster is grooved differently than the video) then First turn the big wheel by hand a few times to "unlock" it's stiffness. Then remove the big wheel and belt. Oil both of the spindles with MACHINE OIL ONLY (like the first article emphasizes)--I used sewing machine oil. Mind you, I did this with my machine upside down to be sure oil ran down the shafts. Then re-assemble. This was a BBBBitch to do until I discovered the spindle on the big wheel is shaped like an elongated D. Once you figure that out, it will drop down easily. I stretched the tight belt back on by fitting it first into the smaller paddle end (to be sure the grooves are in place) then putting it around the big wheel, holding loose part with thumb and turning the wheel until it fell into place--sort of like a tire machine. (see attached picture) Now give it a few more spins by hand (it should spin freely) and replace bottom of machine. Voila. Mine is working perfectly now, and I hope yours will too.
Feb 10, 2009 | Oster 5834 ExpressBake Bread Maker
Paddles stick to posts & tear big chunks out of bread
Try some hard crisco on the post before putting in the paddle or any ingredients. Your paddle SHOULD COME OUT with your loaf. Then when it has cooled off some, you turn it on it's side and surgically remove the ****** from the bottom center. Try to remember the shape(of the paddle) you need to excise for your loaf. Have you ever noticed that most kitchen machines are designed by men?? As with floors that are horrible to try to clean. The big belief is that all companies have test kitchens.. not so. And we my dear must deal with items that do not function as one would logically think they should. I hope you give the company an earfull of customer feedback. Mine is an OSTER. Five 1/2 years and doing fine even with whole wheat, and desert pastry.
Sep 28, 2008 | Black & Decker B2300 Bread Machine
Oster 5836 ExpressBake Bread Maker Logo
19 people viewed this question
Top Oster Breadmakers Experts
Irene Tulloch
Are you an Oster Breadmaker Expert? Answer questions, earn points and help others
