Question about Photography
Camera i dont know how you insert the film on a menalta x-300s?
  • k-kay-tee Nov 09, 2008
    THANK YOU SO MUCH!
    Novelist:
  • 208 Answers
I'M GOING TO ASK IF YOU HAVE THE CAMERAS MANUAL? IF YOU DON'T, I STRONGLY SUGGEST YOU GO TO THE MINOLTA X300 SITE ON THE WEB AND READ THE ONLINE MANUAL FOR YOUR CAMERA. YOU CAN ALSO PRINT PARTS OF IT YOU FEEL YOU NEEDTO HAVE FOR REFERENCE. THIS CAN BE VERY IMPORTANT IF YOU PLAN ON TAKING ANY REALLY GOOD LOOKING PICTURES. I CAN TELL YOU HOW TO LOAD IT NOW BUT YOU CAN GO TO THE SITE A LOOK AT IT BEING DONE AFTERWARDS, BASICAL YOU PULL UP ON THE FILM WINDER THAT IS ON THE LEFT SIDE OF THE CAMERA YOU ARE AT THE BACK OF THE CAMERA. SO PULL THISS CRANK UP THAT RELEASES THE DOOR AND IT SWINGS OPEN AND YOU CAN SEE THE OTHER REEL AND KNOB ON THE RIGHT SIDE , TAKE THE FILM OUT OF THE PACKAGE AND PLACE THE FILM IN THE LEFT SIDE OF THE CAMERA UNDER THE LEFT CRANK WINDER WITH THE FILM TAB COMING OUT ALONG THE BOTTOM SIDE LOWER THE CRANK HANDLE INTO THE FILM CAN TOPUNTIL IT SEATS OVER THE NOTCH. NEXT PULL JUST ENOUGH FILM TO THE RIGHT TO REACH THE RIGHT SIDE CRANK SPOOL. IT HAS A TAB HOLDER ON THE BOTTOM WHERE YOU STICK THE END OF THE FILM INSIDE THE SLOT AND TURN THE CRANK SO ONE OF THE TEETH GRABS A NOTCHIT THE SIDE OF THE FILMWHEN IT DOES, JUST WIND IT A COUPLE OF TURNS AND YOUR DONE,THEFILM ADVANCE LEVER SHOULD BE MOVED NOW UNTIL IT REACHES 1 AND THEN CLOSE THE FILM DOOR AND PUSH DOWN THE LEFT WINDER CRANK TO LOCK THE DOOR SHUT,GIVE THE CRANK A COUPLE OF TURNS BACK TO TAKE UP ANY SLACK AND YOU ARE READY TO SHOUT! I'D PRINT THIS OF AND HAVE SOMEONE READ IT AS YOU DO IT AND IT WILL BE EASIER. IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT1217
Posted on Nov 09, 2008
How do you re-load it?
Open the back with the side latch, pull the header of your film out of the roll, insert that into the slot on the roller spindle far enough for it to wrap once, close the back of the camera, and then power it up. It will start to wind to the first photo segment by itself. If it doesn;t the film was not inserted far enough into the spindle.
May 20, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Help with minolta x-300s, i cant seem to move the film winder
Well, here's the most likely things going on:
1. dead battery. Your X-300 has an electronic shutter that needs battery power to work. Try fresh batteries and check the battery contact wires for corrosion.
2. End of roll. If you have film in it, try the silver button on the bottom. rewind film and try another roll of film. Before you put in the new film, try the advance, click, advance, click thing.
3. Not all rolls of film are perfect. Some are shorter than they should be, some hang up in the canister.
4. The Minolta X-series were well known to have a problem. Two cheap capacitors on the later models would die, locking up the camera. One is under the top plate and the other under the bottom plate. These caps need to be replaced. I suggest you send it to a repair shop for that. Check prices. Garry's camera repair in Niles, IL does a very economical repair on these. It runs about $50 and $8 for return ship. He will also Clean, Lubricate and adjust it.
You could also buy another 300/370 on Ebay, as they're inexpensive these days.
Best of luck. Hope its just the film or batteries. You might also consider joining the Yahoo Minolta groups.
Jan 19, 2010 | Minolta Photography
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
I dont know how to load my Nikon 35mm camera. I need instructions
Pull up the film rewind knob to open the back.
Drop the cartridge into the well on the left and, while rotating the rewind knob, push it back down to secure the cartridge.
Pull the leader across and insert it into any of the slots in the takeup spool.
Make sure the film perforations engage the sprocket teeth.
Alternately wind the film lever and press the shutter button until the perforations on both edges of the film engage the sprocket teeth.
Close the camera back, making sure it latches.
Take up the film slack by rotating the rewind knob in the direction of the arrow until you feel resistance.
Make blank exposures until the counter shows "1".
There's a fuller, illustrated set of instructions in the manual, which you can download from http://www.butkus.org/chinon/nikon.htm
Mar 20, 2009 | Nikon FG 35mm SLR Camera
Dont know what type film camera uses
wolfiencus,
polaroid 600 film. watch expiration date. film was discontinued a year ago.
Dec 14, 2008 | Polaroid Photography
Minolta X-300s film loading problem
Hi -- yes if you cannot advance the transport mechanism ( and so cannot load the film ) this is because shutter is not working ! This a very common problem and is due to leaking capacitor ( 220 microF ) situated on the botttom of the camera. Remove bottom cover and replace the capacitor . You should be able now to release shutter and load your film.
Aug 20, 2008 | Photography
I dont know how to put the film in the ricoh kr-30sp
Please go to this link and scroll down to number 6 under the picture of the manual. It says"insert film". Click on that link and follow instructions! Thank you for using Fix Ya!
http://www.butkus.org/chinon/ricoh/kr-30sp/kr-30sp.htm
Aug 16, 2008 | Ricoh Cameras
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
MInolta x-300s film camera - shutter will not work
Remove bottom cover ( 4 screws ) and find small shutter release capacitor ( 6 v 220 microF ) and replace it. These older capacitors start leaking after 8 years and have to be replaced. Make sure you get the polarity and specs right when you are putting a new one in.
Sep 01, 2007 | Photography
Help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Mar 31, 2007 | Nikon FM10 35mm SLR Camera
Photography Logo
155 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
