Question about Beko 324250WN 28" TV
No sound Recently moved to Greece from the UK. Our TV picks up local tv station pictures but no sound. Have reset the Set Up to Ellada (Greece)and played with sound set up, etc. Still can't find an answer. Also my games system works well but, again, has no sound. I wonder if the co-ax socket has been damaged. Any suggestions?
Sound setup is on normal, game system has volume but tv channels dont have sound, just static.
Posted on Sep 07, 2008
    Problem Solver:
  • 4 Answers
Your UK TV is on the PAL system. Greece operates on the SECAM system. You need a multi-system TV or a SECAM one.
Posted on Nov 15, 2007
    Scholar:
  • 68 Answers
The coax. socket is definately OK. Did your games system come from, and work in the UK, or did you buy it in Greece. If you bought it in Greece, then perhaps their sound subcarrier is on a different frequency(to 6MHz). Whatever is the cause you need to go through everything on setup.
Posted on Oct 23, 2006
    President:
  • 3,130 Answers
Check the remote or the audio menu for a SAP setting and change it to normal.. It sounds just like someone has on the Second Audio Program. Good Luck Ps Please dont forget to rate this thread.
Posted on Oct 22, 2006
SOURCE:
One Station only no sound but great picture. The additional digital channels with that station work fine.
Some of the channels have moved. So your TV might be picking them up differently. You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 09, 2014 | Televison & Video
Philips LED 40PFL9704. Switches off before completing the warming up stage.
Sounds like shipping damage---maybe the display panel got damaged.
May 30, 2012 | Philips Televison & Video
I am not a cable television subscriber. Nonetheless, why can't I get my local public television station when this television set tunes in all other local television stations (local ABC, CBS, NBC, Fox...
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
May 16, 2011 | Televison & Video
I have moved to Greece and brought my tv with me. It works perfect as a tv but cannot use the freeview box. Is there something that has to be done to the tv to allow it to be used in Greece or is that...
if greece has dvb transmissions broadcasting then it might be able to be used. But if they dont, then i am afraid its useless, you dont say what country you have moved from, but wherever it is you wont receive the channels you got back home on it anyway. Only channels you will receive are greek channels. Try entering the menu on the tv and tell it to autoscan for analogue and digital channels and see if it picks up anything. If you want the channels you had back home , your only option would be to purchase a sat reciever and use that
Apr 22, 2011 | Televison & Video
Poor reception on one tv channel only rest are fine
If OTA, check that your antenna is pointing at the station's transmitter. Look at antennaweb.org or tvfool.com (antennaweb is very conservative with the stations that it will suggest that you can get. Both assume external antennas.) If you have an amplifier, check if it is working (I lost a local VHF channel recently when the antenna splitter/amplifier got a power surge after a lightning strike - despite it being the nearest station.)
Consider resetting the tv to the defaults and rescanning for channels. (The reset is under Menu > Picture Settings > Advanced Settings (if you use Customized Picture Mode; there is a second reset under Audio settings for those customized functions.)
I hope this helps.
Jun 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi - I've got a Panasonic TX-26XLD60 which I bought in the UK, but have now moved to Greece to live. I've got video but no sound. Is there anything I can do to set it up fro Greece TV format by going...
Unplug,replug the tv back about an hour later let the tv reset itself.Go in ur tv menu go to AUDIO setting.Go down to reset it to factory setting,should get audio back.Not than ur Tuner board have problems.
Apr 23, 2010 | Panasonic TX-26LX60 26 in. HDTV-Ready LCD...
I was living in Beijing and I have moved to London UK and my TV does not work? Can a TV bought in China work in the UK?
HELLO
The answer to your question is NO!
The frequencies and transmission standard in the UK are different from China and that is why it will not pick up any TV stations here in the UK.
You are going to have to buy a UK TV set and my motto is: Always buy a TV in the country you live in!
As for your current Chinese TV - scrap it!
ALL THE BEST! (:-)
Oct 21, 2009 | Televison & Video
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
No sound
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Jul 28, 2006 | Sanyo C40N
Beko 324250WN 28" TV Logo
219 people viewed this question
Top Beko Televison & Video Experts
Marvin
Marvin
Andy Latty
Andy Latty
Level 1 Expert
Steve Allison
Steve Allison
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
