Washing machine does not drain well during discharge cycle
  • Washing Mach... Master
  • 19,396 Answers
Check the drain hose and the drain lines, if they are ok then it is usually dirt or something stuck on the drain pump.
Posted on Nov 08, 2008
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
Washing machine knocks and dims lights only during rinse cycle
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
Jan 24, 2013 | Washing Machines
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Leaking washing machine
The leak is probally coming from the drain pump itself or the discharge hose onnected to the pump. This is easy to check and replace. This video should help
http://appliancehelponline.com/topdirectdrivevideo.html
http://appliancehelponline.com/toploadcabinet.html
Jun 04, 2010 | Kenmore 22622 Top Load Washer
Washer stops during rinse cycle and "OE" code shows up. we've cleaned filter and keep draining drain hose. is there anything else to do or check?
You may have to inspect the entire drain system back to the pump, it may be partially clogged. When the unit drains it should drain a substantial amount of water. View the drain discharge, if it appears the discharge rate is not what it used to be, inspect the drain system
Nov 12, 2009 | LG WM-2277HW Front Load Washer
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Washing Machines Logo
242 people viewed this question
Top Washing Machines Experts
