Question about Canon ZR200 Mini DV Digital Camcorder
Camera takes pictures continuously
When trying to take still pictures, the camera begins snapping a picture every 5-7 seconds. Regardless of what settings I attempt to change, this continues. Sometimes this even happens when the card is not engaged (i.e. when importing video). Is this a problem with the memory card or the camera itself? Anything I can do to fix it, or does it require pro repairs?
  • Billy Earl Brown
    Billy Earl Brown Oct 15, 2013
    Try smacking it twice right front on side behind shutter. Worked for me was fixing the tape closer worked for both.
  • 169 Answers
It is normal on the camera. just avoid pressing the snap button at the upper part near the zoom control.
Posted on Aug 08, 2007
  • christian tope Sep 05, 2007
    i think it need to be service your camera now cause some contact of the switch are having a resistance or been shorted...cause that wiring is made of carbon....it have to clean the switch and the terminal contact cause of some carbon build up you will notice this if the terminal and switch are not color silver ..don't attempt to clean that if you are not a technician...is our shop we simply clean it buy a pencil eraser....
Everytime I take a picture with my Nikon D40 the pictures are...
Try holding the camera steady for a couple more seconds after you snap the picture.
Aug 20, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon D40 is taking a long time to shot picture
you should have swithced the cam to timer mode....modify it...since you are unable to take pictures try to reset(initialize) your camera...that should help
May 13, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
I wanna take a picture but i dont know how to make the camara wait 10 sec before it takes the picture
Self-timer shooting:
This function lets you take pictures using the self-timer.
Fix the camera securely on a tripod for self-timer shooting. This function is useful for taking
pictures when you want to be included in the photograph.
1 Select [ON], and press Z.
2 Press the shutter button fully to
take the picture.
• Pressing the shutter button halfway
locks the focus and exposure.
• The self-timer lamp lights for
approximately 10 seconds, then starts
blinking. After blinking for approximately
2 seconds, the picture is taken.
• To stop shooting while in n mode,
press the shutter button fully again.
• To cancel the self-timer, press Z.
• The self-timer mode is automatically canceled after one shot.
Note:
• If sequential shooting is attempted in self-timer mode, the camera shoots 5
frames at most regardless of the setting.
Hope my info fixes your problem,
Thanx for using fixya,
cheers.
Sep 26, 2008 | Olympus Camedia D-595 Digital Camera
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Auto reset following each picture shot
Well most digital cameras are not equipped to allow to take a lot of action photos or just snap off various pictures of the same subject in a relatively short time. The models which are ill-equipped require more time between shots to save the image to the memory card. Just imagine the time it takes to save something on a disk. Keep in mind that the burst mode allows temporary storage of images. This way, you could take as many pictures as you can in no time. With the Nikon Coolpix 4300 Digital Camera, you can expect to find a shutter speed of 1/1000 to 8 seconds. One more camera feature include a Self-Timer mode, which provides a three- or 10-second delay between the time the Shutter button is pressed and the time the image is actually captured... Good luck!
Oct 23, 2005 | Nikon Coolpix 4300 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Canon ZR200 Mini DV Digital Camcorder Logo
35 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
