Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
MY Samsung HCN4226W have perfect sound but no picture
My television began showing a red sceen with horizontal lines. Finally all of a sudden sound stayed on and screen went totaly dead. I tried adjusting the F/S adjuster and the HV adjuster but no result. Manufacture date is August 2003, serial number 3CEW800594A. Your help will be greatly appreciated.
  • Richard Philbert Oct 28, 2006
    After reading some of the posts, I finally decided to order the convergence amp board.I replaced it with the old one, unfortunately I am having the same problem. Aditional help would be greatly appreciated.
I had the same experience with my set. I noticed there were 2 new cables attached to the new board and looking carefully noticed the connectors were different from the old. The new connector fit perfectly into the new board but wasnt the same as the old. I replaced the old cable with the new and the TV remained bad. I then flipped the connector to the main circuit board (bottom left) and the new board worked fine. I know nothing about Tv repair, but this new cable seems to be a universal connector in which the contacts are open on 2 sides...allowing them to be flipped if necessary. Now if I could get that solid line out of the display I'd be set!
Posted on Dec 01, 2006
36' toshiba with red screen and glowing horizontal lines.
Bad connections on red drive transistor on crt module. Resolder all connections on crt pcb.
Nov 25, 2011 | Televison & Video
Green Picture
Sounds like you are not getting a red in your feed. Have you check the feed into your tv or if the cables are having a problem?? check it and let me know........
May 27, 2010 | Samsung HCN4226W 42" Rear Projection...
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
My samsung hcn4226wx rear projection tv
IT SOUNS LIKE YOU NEED THE Convergence Module BP9500415B BP95-00415B
Feb 28, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCL552W
these have been know to have bad convergence ic but that would only be a guess as to whats wrong i would have someone give you and est.
Jan 14, 2008 | Samsung HCN4226W 42" Rear Projection...
Color is off and looks like a fish eye look
sounds like convergance ic bad.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Samsung HCN4226W 42" Rear Projection...
Red
ok when you say all red there is not other colors at all?
otherwise i would recommend this if you see other colors.
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Dec 18, 2007 | Samsung HCN4226W 42" Rear Projection...
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42
Check to see if you have the 117 volts you need to power the Flyback Transformer. You can test this at the connector labeled CN801 at TP61 and grd. If you do not have power here check the fuses around the T801S Transformer. They are little green components that look like resistor and labeled with an FD.
Nov 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
1,094 people viewed this question
Jerry Greenberg
Jerry Greenberg
