Question about Black & Decker Leaf Hog Blower Bv4000
BV 4000r not turning on when plug in to electric current
  • 2 more comments
  • frenchfryman Dec 01, 2008
    No power after emptying bag No obstruction Is there a fuse somewhere?
  • Anonymous Dec 31, 2008
    leaf blower will not turn on afer attaching to power
  • 7thlaker Jan 05, 2009
    I have same problem, so I took the power head apart and found that the motor and the internal 2-speed switch are OK, except that you have to hold down the switch in either position. I can get the blower to run at both speads by bypassing the convoluted plastic switch activator, which is the real problem. Does anyone have a recommendation on where I can get a different 2-speed switch that I can somehow mount on the handle?
  • Anonymous May 11, 2009
    same thing just no power it seems like. anyone have a fix?
No power to fan motor checked fuses & cleaned all elec. connections.
Does it have a relay? Have you checked that? Also did yiu check the off/on switch? Check for broken wires also. Also check thermostat.
Jul 02, 2015 | FAN-TASTIC VENT 4000R-BRIGHT WHITE - 12V...
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
What causes the prong on my RV electric plug to turn dark? Have replaced the plug because it looked damages but the new plug is starting to turn too.
The plug is turning dark because of the heat generated by the electrical current running through it. This is common and nothing to be concerned about. However, if the plug is getting too warm, it is an indication that the wire size isn't adequate for the amperage and you may consider using a larger gauge wire.
Jul 06, 2010 | Electronics - Others
I'm installing a led tailight on a 99 zx7r motorcycle and it has 3 wire in the plug (stop,running,and ground) then there is 2 other wires one for left and right. Well when you wire the turn singles in they...
apparently a wire is crossed somewhere.. if you think about it it's quite simple... it begins as a single wire of electricity triggered from the turn switch, then down to the plug... if crossed over anywhere it will trigger what it has crossed.. try getting an electrical tester and check all the connections before inserting the new plug..
ex: turn on left signal, use electrical tester to the connections making sure it's only flashing one connection.. if so, you know it's the plug, examine it for any defects at all and also check the compatibility once more with your bike.
Sep 17, 2009 | 1999 kawasaki ZX-7R
The dishwasher acts like there is no electrical current to it.
Try a lamp in the socket to see if there is power. The dishwasher may have a circuit breaker.
Jul 11, 2009 | Dishwashers
My sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Feb 19, 2009 | Sony CDX-4000X CD Player
Sony CDX-4000R car audio
One of my sons (40+ yrs) found the answer on the net which was yes it does, and e-mailed me. Incidentally the unit was a Sony CDX-4000R and not a Panasonic etc.
Oct 05, 2008 | Panasonic RX-D11 Cassette/CD Boombox
IBM starting problem.
Hi , if your dont have any data, try to get the IBM Netfinity CD for 4000r which supporting the OS 2003. Usually IBM provide a cd on each NEtfinity server. Check on the IBM website for more details about your Server Compatibility on 2003 server. then proceed to re-intalled the OS.
Aug 10, 2007 | IBM Netfinity 4000R 8652 Server
Black & Decker Leaf Hog Blower Bv4000 Logo
193 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
