Question about Sunbeam Heritage 2346 Stand Mixer
Mixer beaters clanging together
My daughter was being careless when she was making muffins and let the wooden spoon get stuck int the beaters. Now the beaters hit and clang together if you try to use the mixer and the bowl does not spin anymore. Consequently, the batter is not being mixed evenly. Is the problem fixable or is the mixer done for? Thank you very much.
  • Anonymous Dec 05, 2008
    The beaters will not turn most of the time unless I turn them to start them the they sound clanky The turn table is fine Thanks
  • gypse2 Apr 04, 2009
    I have exactly the same problem for the same reason except it was me who left the spoon in.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Posted on Nov 09, 2008
I need beaters for my breville stand mixer model number vfp026 please advise
Check with a local appliance parts supplier. If no luck, contact Breville directly to determine availability and source.
Aug 12, 2016 | Breville Food Mixers
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
The flat beater is stuck in the mixer and I can't remove it.
oh yes you can.:) pur some wesson oil into the sockets the beaters go into and a little around the button.. Let set a few minutes and work the beaters back and forth as you pull gently. Make sure it is unplugged!!!!!
Oct 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater is stuck on the mixer. No leverage when I
Still stuck? It may need to be turn backwards by hand . poswsibly jammed on locking mechanism Try twisting it back and forth. . make sure to unplug.
Oct 26, 2009 | KitchenAid 32685 Mixer
The beaters were clanging together. Now the
the gears were out of sync, by this time their probly stripped. IF you can get the gears, one must resemble a X and the other must resemble a + when installed, so they look like this X+ that way they wont hit.
Oct 17, 2009 | Black & Decker 220 Watts MX77...
Wooden spoon killed the motor!
these mixers use an electronic triac(to vary the speed of the mixer) of such low amperage that they run hot normally(to wear OUT), and they don't fuse the units electronics or motor anymore so anything that binds them will short out the triac or motor winding(from heat) and make them inoperable,try and order(what they call) an internal electronic part from these companies and good luck, I tried for 3 months and told them what I needed,they agreed this part was defective, but they wont sell you an internal part(LIABILITY ISSUE) unless your a "company certified technician" go figure, I finally got one through N.T.E.semi-conductors. and my customers HAPPY NOW!!!
Oct 06, 2009 | Sunbeam 2366 MixMaster Series Hand/Stand...
Kitchenaid k45ss won't turn on
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Jan 25, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Bravetta mixer
Call Euro-Pro Operating LLC at (800) 798-7398
Aug 30, 2007 | Bravetti 35-396 Power Hand/Stand Mixer
Sunbeam Heritage 2346 Stand Mixer Logo
753 people viewed this question
Top Sunbeam Food Mixers Experts
Custom Exchange
Custom Exchange
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
