Question about Dell Inspiron 6000 Notebook
Doasnt charge i have the inspiron 6000 and i have a problem.the charger and battery both work i have tesed them but it wont detect the charger but the battery is fine and the charger is fine the problem is the laptop doasnt detect the charger can anyone help
  • Dell Master
  • 19,396 Answers
Often this happens because the AC soket in the laptop has a broken contact.
In this case the tehnician access the motherboard and resolder the on board contacts.
This is not a job for beginner, requires taking apart teh laptop completely, taking out the motherboard, and doing a precision soldering on the motherboard.
Ask a quote for the repair at a local repair shop, or call Dell and ask the cost of a Warranty extension that will cover factory repair, usually is cheaper than the repair job.
Posted on Nov 08, 2008
My Inspiron 6000 won't charge the battery.
According to your problem, this may occurs for either the battery of your laptop or the charger is faulty. First check electric outlet where you have plugged your laptop charger is OK. Then check the power cord. If everything OK then you have to change the battery.
Jun 10, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
New battery will not charge on inspiration 6000 works fine when plugged in?
a hundred to 1 your chrger is ****. Though it will still keep it powered doesnt have enough connection to give it a full charge. I had this same laptop and with the same problem. go to ebay and buy a new charger for 15 bucks and your problem is solved. In the future always try the charger first ...they are always cheaper than a new battery!
Mar 13, 2010 | Dell Inspiron 6000 Notebook
Either battery is not taking charge or battery charger is not charging the battery. You can take to a local PC repair center and have the battery tested. If it is battery, you can find OEM replacements online from companies that do nothing but batteries and typically beat manufacturer part prices.
Oct 19, 2009 | Dell Inspiron 6000 Notebook
I have a Dell inspiron 6000 battery problem
try to remove the battery out from ur laptop then clean its terminals from any corrosion (By scratching it using a screw or something like that) then after 5 min. try to install it back again then connect the laptop to the charger hope it works
Jul 22, 2009 | Dell Inspiron 6000 Notebook
Battery alarm flashing orange on dell dell inspiron 6000
flashing because it is very low.
If you charge-it and still flashing it seems to have o problem with battery, charger or even the laptop. Try to test the charger and laptop with another battery and see where is the problem.
Jul 18, 2009 | Dell Inspiron 6000 Notebook
My dell inspiron 6000 wont charge but i dont think the battery is the problem. The powerlead also still has its light on so must be still working. Any suggestions?
Could you check the output voltage of charger with multimeter? If you find output voltage then your charger is OK, Might be some problem with charging cirucit diagram of the laptop. If no output then replace your charger with new one having same specification.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Jul 12, 2009 | Dell Computers & Internet
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Update laptop bios go check for update of your laptop model....
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
79 people viewed this question
Alun Cox
