Question about Maytag M7DH65B2A Dehumidifier
Ground fault as soon as I plug it in.
I was given this dehumidifier by a friend. It work great for a while then all of a sudden it just trips the GFCI breaker in the wall outlet every time you plug it in. The house circuit and outlet are at 20amps. There are no obvious burn mark inside. Any thoughts? I am finding it very difficult to locate a service center for this model. Thanks, JPT
I have a Maytag Dehumidifier Model # M7DH65B2A *A. When I plug it in, it trips the GFCI. The coil is clean. Do you have any tips for a solution?
Posted on Jun 15, 2008
Make sure the coil inside is clean. I own three units and all stoped working, triping breakers ect untill I cleaned the coil, It was jammed with dirt.
Posted on May 04, 2008
You more than likely have a dead short in the compressor
Posted on Nov 09, 2007
My soleus dehumidifier keeps tripping my fuses on my powerstrip so we have to keep resetting it. Why?
If it is a GFI protected powerstrip then you likely have a ground fault issue, otherwise the powerstrip may be overloaded (unit should pull around 5 amps on startup) or faulty.
Sep 25, 2011 | Soleus CFM-40 Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Every time I plug my dehumidifier in to the ground fault plug the ground fault goes to failsafe. I tried another circuit and the dehumidifier didn"twork. I tested the outlets with aplug tester and they are...
You will find that the compressor is bad and will not start...this kicks out the receptacle.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 17, 2010 | Maytag M3DH30B2A Dehumidifier
Dehumidifier trips ground fault outlet and no water in bucket
The compressor is trying to start and pulling high amps which trips the GFI...
You are better off replacing rather then repairing that unit.
heatman101
May 17, 2010 | Haier 45-Pint Dehumidifier
My Fedders A7DH45B2A dehumidifier (about 4 yrs old) continues to trip the fuse embedded in the outlet on the wall in which it's plugged in.. What gives??
either try a different outlet to see if the G.F.C.I. is bad on this outlet or if the dehumidifier trips on another line it could be the units motor start capacitor that shorted or the compressor is bad
Apr 06, 2010 | Fedders A7DH45B2A Dehumidifier
AD50USR Whirlpool Dehumidifier trips circuit breaker
Not very likely check your paperwork what warranty did you get when you purchased this unit? you might have completed some papers and returned them to an address for the warranty to be accepted. It sounds to me like the unit is going straight to earth when switched on, this looks like a compressor fault, but would have to be checked to be sure.
Jul 20, 2009 | Whirlpool AD70USR Dehumidifier
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Dehumidifier
See if you have a grounded circut in the appliance. Check 1 flat to your volt ohm meter. Connect the other probe from meter to the other flat. And you should get a reading of resistance. Next connect 1 probe to the flat then the other to ground. A reading - indicates nothing until the next step. Now try the other flat to the ground?
1 Of these flats are connected to the nutural and possible feed through or back to ground in the appliance. The other one though should not read to ground. If you get a ground reading on both flat of the plug in someting is together that should not be.
If you dont get a readign try plugging in at a different outlet. A circut that has too much load will cause circut breakes to over heat and trip.
If it runs at a different outlet make sure its on a different breaker. If its on the same breaker it will probably start acting up again.
DOes this help? If so please rate me as high as possible If not please restate your problem to help me understand it better. Thnaks for using Fixya and Good Luck.
Aug 31, 2008 | Whirlpool AD70USS Dehumidifier
Circuit breaker
SOUNDS LIKE TO ME THAT YOUR DEHUMIDIFER HAS A SHORT. SOME TIMES ITS THE PLUG OR THE CORD BUT MOST TIMES IT GETS OXIDATION FROM MOISTURE INSIDE.
Jun 24, 2008 | Kenmore 53509 Dehumidifier
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
610 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
