Question about GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker Extra-Large Capacity Portable Washer
Hello i need a service manual for this mashine , it keep beeping and the motor won`t start . thanks for you help
model # is WSLP1100DWW -
I was using a defective extension cord, the machine should trip when start it . and beep with no other message on the screen
Posted on Nov 09, 2008
GE WBXR1060TAWW, Top loading high capacity washer. I need the specs, capacity and number of speeds?
The (X) in the model number stands for extra large (2.7cu ft) capacity. The 1 stands for single speed. The 6 stands for 6 cycles. It should have a white plastic clothes basket. More expensive models had a stainless basket. Hope this helps you.
Apr 15, 2015 | GE Washing Machines
Do I keep my old Kitchenaid extra capacity or keep the new GE GTWP1000
The GE has a capacity of 3.3 cubic feet. You did not list the model of the kitchenaid. Make sure the GE was stored correctly because if it might have lost oil or gotten brittle belts or gaskets. Also it might have frozen.
Feb 22, 2014 | Washing Machines
Ge dryer only works if start button is pushed in model #gtdx100emoww
The start/run switch on the motor is stuck, usually with lint. Clean everything with a vacuum while you are in there.
Nov 22, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity...
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
Washer stopped spin cycle smell like burning rubber
hello if the belt is broken quite easy to put back on .take the back off you should see the belt if it has snaped or just come off .at the bottom of the washer you should see the motor at the back of the motor you should see 2 nuts this holds the motor on get a felt tip pen and mark the 2 nuts where they are fixed so you know where to tighten back on . get spanner and loosen the 2 nuts the motor should drop down put the belt back on and tighten up good luck
shaun
Mar 31, 2009 | GE Washing Machines
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE Spacemaker WSLP1100D Top Load Washer Logo
396 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
