Question about Microsoft Excel for PC
Exel Hi I want to set up a stock control spread sheet for stock on hand, and be able to add goods recieved and minus goods taken. For the goods taken and goods recieved i would like to be able to enter them each time in the same cells and have it add or take away from the stock on hand and then reset so i can put the next value in the same cell. I also would like to have the stock taken linked to certian projects and it be able to do a count and report eeach year so i know what goes out and to which project. Am i expecting too much ? thank you
  • Microsoft Master
  • 2,794 Answers
That might be too much for a spreadsheet to do. It's easy to set one up to show what you have on hand and what you took out. The links to certain projects, I would need more details about.
A better way to do it is to use Quickbooks. That way you have a history of who purchased a particular item as well as when you replenished it. Then you can generate a spreadsheet from Quickbooks as well. You can have your invoicing, receivables, and payables as well in one program.
Posted on Nov 08, 2008
How do I pull a figure from a spread sheet and add it to another in the same file.....
Are you talking about different worksheets in the same file.
go to the other worksheet then go to the particular cell and press = on keyboard
then use mouse to select the other worksheet from the bottom of the spreadsheet .
Then click on the cell you wish to link and press enter key on keyboard.
https://support.office.com/en-us/article/Insert-or-delete-a-worksheet-19d3d21e-a3b3-4e13-a422-d1f43f1faaf2
https://www.microsoftpressstore.com/articles/article.aspx?p=2447199&seqNum=2
You can also do this to spreadsheets with different file names by opening both spread sheets in different windows and switching between the windows.
you can also copy just the data by copy whole sheet (click on the square in top left hand and copy and then right click paste special on new worksheet - with values only rather than the original formulas from the spreadsheet
Jan 06, 2017 | The Computers & Internet
Add information to grayed columns
any greyed out area is a non accessible are
either the spread sheet your are using is not advanced enough or that area is read only requiring an administrator's authority to access it
suspect that it is read only and is not for editing
if you go google and type in -- user manual for excel spread sheet-- there is a pdf version ( around 900 pages ) which has everything you need to know for excel spreadsheets
a good publication if you spend lots of time in excel as it misses nothing
May 11, 2017 | Savy Soda iSpreadsheet Free
.xlsx file doesn't open in
try to uninstall the MS Ofice by clicking start > control panel > Add or Remove programs then remove the Office. Restart pc and install the Office using your CD. Hope that your XLS sheet will come true...
Feb 22, 2011 | Computers & Internet
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
Need to make gluten-free bread
bobs redmill gluten free mix for bread machines. we just use the standard bake setting but select B for doneness level. found it gets a little too dark on A.
Mar 20, 2009 | Toastmaster 1183N Bread Maker
Exel files slowly open
Hi Sahil,
This can be difficult to resolve on the first pass because there is so many things to consider. I have no idea what your experience with excel or computer maintenance is. All my training in industry has told me is go for the "low hanging fruit" first (try the easiest stuff first).
1) When did you last defrag your computer. That can be a fast easy fix. I don't know what your operating system is but you may have a defrag program included as part of the system.
2) How much memory do you have installed and if you have added some did it match what you had installed because memory will run as fast as the slowest stick installed.
3) Any other programs running in the background? My antivirous program is scheduled to scann at specific times when I would normally not be trying to be productive with my favorite programs. I have all the memory installed that I can and if my antivirous program is running and I try to do something else my system tempts me to persue fishing instead of computing just so I could use my machine as a anchor.
4) Do you have an infection of malware to contend with? When has the last time been that you scanned your system for system leaches.
5) was there a specific time that the software slowed down and if so what was done to the system at that time. Can it be undone?
6) Are you the only person on the machine?
7) Just how slow is slow? My machine takes 2 sec to load excel - 5 sec to load a spread sheet that I have been collecting data on stocks for 3 years but is a rocket processing the data and developing the individual graphs that is responding to the macros commands.
So is your expectations of the program realistic?
Investigate your issue and try to reason out what could be going on. Collect more data about your system so I can better guess from wayover here.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Evenif this is not what you wanted to hear please don't forget to rate the answer. I can always learn from your opinion of the service provided.
Thanks
Glad to be of assistance
Oct 21, 2008 | Microsoft Excel for PC
Need a formula for excel
select CONDITIONAL FORMATING in Format
select FORMULA IS , CELL VALUE = > < (condition)
after this select Format
font style , COLOR
SEE IT WILL WORK CHANGE OF COLOURS ........
Oct 10, 2008 | Microsoft Excel for PC
Excel formula creation
= (a3) minus (b3) won't do it for you?
Sep 05, 2008 | Excel (SS8SATAS5128400R)
Problem with columns
In Excel 03, I went to Help, typed in "column" and they had a "add or delete columns" topic. Did seem to answer your question. Very modestly submitted. I ain't no expert, just nosy.
Jan 26, 2008 | Microsoft Excel for PC
Formula required
at first select the 1st page data and select data-subtotal from the upper menu list.
then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
If not solved pls get me that data as to reference.
thanks
Dec 04, 2007 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
