Question about Canon imageRUNNER 5000 Copier
Error code 000002-0010
It was out of toner so I'm not sure if something had to work too hard and broke. Either way it just wont let me past the error and then self shuts down.
Thanks in advance
  • Neko2 Nov 08, 2008
    Still broken, but at least I know why now.
    Thanks
    Problem Solver:
  • 5 Answers
You need to clear this fuser roller heat rod error in svc mode.
Additional Functions="star"
2and8= hit both keys same time.
Svc mode= star 2and8 star
copier/functions/clear/err/ok
reboot
If there is areal problem with fuser heat rods it will code again.
Posted on Nov 08, 2008
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
SC 500 error code on a Ricoh MP161
main motor can turn that is why getting code. can be from photo conductor, to fuser or gear broke in back of copier. Will need tech for this one.
Feb 20, 2012 | Ricoh Aficio MP 2000 Black and White...
(6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
May 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Oki Printer c3200 error code
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
Error code C0070
check where the toner motor is there is a white plastic piece in the toner section that the motor goes into make sure that there is nothin wrong with it. it could stop the toner from turning and that could cause the code.
Motor could be bad or home position sensor could be dirty.
Also make sure it is not a generic toner, some people have had problems in the past with generic toner bottles, also if you have had the back cover off the machine make sure the sensor on the bottom left hand side is actuated.good luck
Jul 31, 2008 | Office Equipment & Supplies
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Error code
toner chip is gone replace cartrige
Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
Canon imageRUNNER 5000 Copier Logo
245 people viewed this question
old marine
old marine
