Question about Air Tools & Compressors
2000 Silverado won't start
My 2000 cheverolt silverado 5.3 won't run. I replaced the fuel filter immediately after the problem and it did not fix it. It does start for a minute but idles very low then dies.
  • joe1920 Jan 05, 2009
    2000 silverado will run on idle for ten seconds but dies i changed the fuel filter but nothing changed
I had a 99' with a 5.3 motor and it would die on me once in awhile, and it took awhile for it to start some times. It was the fuel pressure regulator, i learned later that this motor had alot of problems with this regulator. Changing it fixed it for aboout 50 bucks and 10 minuits or work
Posted on Apr 01, 2009
I have had to change my distributor cap on a regular basis every 10 to 14 months ever since I bought my silverado in 2000. No one has been able to explain why but out of no where the truck will not start turns over but refuses to start every thing else checks out but it still won't start, until I replace the distributor
Hope this works for you.
Posted on May 15, 2009
    Scholar:
  • 36 Answers
Hi, first check to see is there fuel getting to the engines fuel pump,
Then if fuel is being pumped it must be the ignition system.
Is your engine Gas or diesel?
Also check your knock sensor connection ( also called map sensor ) this is usually fitted around the flywheel area somewhere.
If this is disconnected the engine will start then cut out shortly.
Posted on Nov 27, 2008
Having trouble keeping my Chdevy Silverado running
Have you had the system scanned for fault codes?
Jun 07, 2013 | 2000 Chevrolet Silverado
2005 silverado cranks but won't start
I had the same problem . on my 2002 silverado it turned to be the fuel pump failed because the fuel filter was clogged. I did the work myself could saved myself 219.00 and labor if I replaced a 7.00 $ Filter .
Apr 25, 2012 | Cars & Trucks
I changed the fuel filter in my 2004 silverado and now my truck won't start
It would be nice if you were to mention WHICH ENGINE your Silverado is equipped with...Knowing WHICH Silverado MODEL you have would also be nice...1500, 2500, 2500HD, 3500. etc.
If it is a gas engine, all you should have to do is to cycle the ignition key ON for about 5 seconds, then turn the ignition switch OFF and wait about 30 seconds, then repeat this about 3 times. This will allow the fuel pump prime to get the air out of the fuel lines. It should start after this is done.
If your truck is equipped with a diesel engine, the process is much different, let me know if this is the case, and I will post the fuel filter replacement instructions for the diesel.
Aug 06, 2011 | 2004 Chevrolet Silverado
I have a 2000 chevy blazer with a 4.3 vortec motor,my problem is when i'm cruising at a steady speed the engine surges it usually happens around 45-50 mph
ENGINE SURGING COULD BE WEAK FUEL PUMP, STOPPED UP FUEL FILTER,BAD TORQUE CONVERTER SOLENOID OR TORQUE CONVERTER. OR FAULTY TPS.
Dec 30, 2010 | 2000 Chevrolet Silverado
2000 silverado 4.8 v8 runs bad when it is cold out side.
Try replacing the coolant temperature sensor for the injection system.
Jan 05, 2009 | 2000 Chevrolet Silverado
Turn over but well not stay running backfires though air intake
When is the last time you replaced your fuel filter? Check your fuel filter. If it's plugged you may have taken out the fuel pump. This happened to me. (2000 Chevy Silverado 1500)
DC
Jul 29, 2008 | 2000 Chevrolet Silverado
Fuel filter
The Fuel filter should be along the frame on drivers side under cab towards back on extened cab it's silver about 4 to 5".
Jul 03, 2008 | 2000 Chevrolet Silverado 1500
Air Tools & Compressors Logo
596 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
