My living flame gas fire has started to have all the flame at one side (side of the pilot light) and sometimes the flame goes underneth the fire? why
    Champion:
  • 254 Answers
A couple things could cause this.
1. you have air flow pushing the flame to one side
2. A dirty burner.
3. A plugged outlet oriface.
Posted on Nov 15, 2008
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
The pilot light will not stay on for more than 5min. If I light the fire when its on,it just goes out. The fire is a Fusion 2/7
I assume this is a gas log? If so, you have dust in your pilot assembly. Turn everything off and let it cool. Note the opening where the pilot flames burns. Use the wand from your vacuum cleaner and place it over the opening for the pilot flame. Gently tap the side of the pilot assembly while holdign the vacuum above the opening. This will lift the minute dust particles out and allow the flame to burn nice and blue again. These logs have Oxygen Depletion Valves on them. The pilots are very sensitive to dust.
Jan 18, 2011 | Heating & Cooling
Our pilot light does not stay on...sometimes when temperature changes out side
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out as the outside air cools.
Sep 21, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Dryer starts up and flame starts for about 3-4 minutes and then flame goes out.
The pilot light lights? Then goe's back out? There is two stiff wires right in front of the flame. One of them is an ignightor, and the other one a thermocoupler. Or may just be one. That is the ignightor and thermocoupler. The thermocoupler is what detects that the pilot light lit. Its a saftey feature. It makes sure that there is fire before it turns on the main gas. So it wont blow up. It gets a film built up on it from the gas. Take some real fine sandpaper, or steel wool and clean it real good.
Then try again. It should work. If not then it needs to be replaced
May 21, 2010 | Whirlpool LGR8648 Gas Dryer
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Fireplace pilot light continually goes out
You may have a problem with the flame sensing capillary. It may need to be replaced, or it may need to be positioned into the pilot flame better, or you may need a new gas safety valve. Sometime there is an adjustment screw for the pilot which can make the flame bigger or smaller. If will be on the safety valve.
Oct 14, 2008 | Grilling
Bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Apr 21, 2008 | Ovens
Heating & Cooling Logo
151 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
