Question about InFocus ScreenPlay 4805 Multimedia Projector
Knoll hd-102 projector
There was a shadow on 1/3 of the screen and then 2 days later 3/4 and then no picture. the lamp checked out ok.
Let me start by saying that my projector is an InFocus Screenplay 4805, but that I have had the shadow you're talking about on the left foot or so of my screen for about 18 months now. I've researched it and found out that it has something to do with the glue holding something called a "Light Tube" in place heating up and essentially becoming liquid enough to allow this light tube to shift positions...the further out of position it gets the more of that "eclipse" effect you see on the screen. It sound like yours has shifted far enough that no light can pass through it at all.
Posted on Nov 12, 2008
Sanyo plc-xe20 no picture
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Apr 13, 2013 | Sanyo PLC-XE20 (Chassis XE2000)...
I have an Optima HD 8000 DLP Projector and have had it for a year. The issue I am having is that the projector works find but for only 3-5 minutes and then it turns off and the Lamp Indictor turns on. Any...
hi,
First of all check the lamp hour of projector. just reset the lamp hour and try again.
1. Press the menu button
2. Select system
3. Then select lamp reset
4. Select reset
The lamp hour will be retested.
Try to do this before you projector turns off. it is recommended that do this only after replacing the lamp.
If doesn't work then check the following
Check the lamp cooling fan of your projector . may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 31, 2011 | Optoma HD8000 Projector
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
hi,
its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
1 Press and hold the Exit (up arrow) button on the projector for 5
seconds to display the total used lamp time.
2.Press Auto button the projector or on the remote control to
reset the lamp hour to "0".
3. Wait about 5 seconds to let the OSD disappear.
ok
Dec 22, 2010 | BenQ PB6110 Multimedia Projector
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Nov 17, 2009 | NEC NP60 Projector
I have a 46 Toshiba DLP television
Hi,it does sound like it could be that mirror since thats what direct the light of the lamp.You will need to replace the light tunnel.
Oct 05, 2009 | Toshiba Televison & Video
Elmo slide to video projector
check the resolution. is your tv hd? the projector may not be.
Aug 20, 2008 | Elmo Projectors TRS-35XG 35mm 80 Slides...
DLP projector BenQ MP710p
Actually you can turn the projector on and then tilt it in all directions and see if picture shadowing changes. I have experience with this issue on DLP TV'S. IT sounds like a light tunnel problem if you can see partial picture behind shadow. It is fixable but very tedious. But can be done. Do you have a picture of the problem that you could send over? Thanks Jay
Jan 03, 2008 | BenQ PB7220 XGA DLP Projector Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
87 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
