Picture is green have tried to adjust will not help
  • 1 more comment
  • manpa Nov 10, 2008
    hitachi model 42v515 sn v4k005790
    tv is 3 years old. a year ago we had to replace lamp because it blew out.
    the screen is green no matter what component. when turned on is green stays green no matter what you watch or how long.
    President:
  • 1,314 Answers
What kind of tv is it?
Posted on Nov 10, 2008
  • 10,594 Answers
Please mention model and brand of your TV to look into schematics for subject problem.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Nov 10, 2008
    Please let me know how old is this TV and have you replaced its Lamp?
    Let me know do you get green picture on all inputs or any particular input? like dvd component input
    Thank you
    Problem seems with light-engine as Lamp is still OK.
    Please contact Hitachi Service and I'm sure this would be costly repair.
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
Jul 30, 2011 | Sony KP-51WS500 51" Rear Projection...
We have a Hitachi LCD rear projection Tv, 42V710,42V715, The picture has alot of green in it, tried ajusting the color, still a hint of green. It was fine until about a month ago. Every thing esle is...
You need to adjust the Green Screen Drive Located on the Focus/Screen Control Block Their will be 3 on Top to adjust Focus to each Tube R/G/B and under it is 3 Controls to adjust Screen Drive to each Tube R/G/B . Cleaning the mirror and Top of Tube Lenses will help improve Picture also if they are Dirty. Control Block is Located behind Front Bottom Panel Pull it off and you should see it.
Oct 05, 2010 | Hitachi 43UWX10B 43" Rear Projection...
My color seems to be more green than should be and I have tried to reset the color with no help
You have a focus/screen control box Find it and adjust the R/G/B screen drives When you first start Go to Menu turn Color off then with a mirror adjust the picture as close as you can to a black and white picture R/G/B screen drives, the little control box you are looking for will have 3 controls on top for focus and 3 controls under them for screen drives to each tube red,green,blue after you have adjusted to a black and white picture then go back and turn color on.
Nov 30, 2009 | Akai PT4298HD Rear Projection Television
My convergence is fine but after professional replacement of the board there is a slight bowing and slanting of in-screen borders and some channels have a little distortion at the top of the screen. The...
First: If the convergence board was replaced--the set may need a total adjustment---this is why most good techs replace the convergence chips and any bad parts instead--also costs less----Second: to enter the service mode (it is done with the set already turned on) should be Mute, 182 or Mute 183---if you get the convergence mode--7,8, 9 will select red, green, blue, 5 will stop the cursor from blinking and allow adjustment---with the cursor blinking 2,8, 4, 6 will allow you to navigate---depending on the remote used--the P mode button will take you across the screen in a series of steps--the remote I use for this has a button on it marked data save--this saves the adjustments. Your remote may have it or a different button for this.
Understand---if you get into the convergence mode---Green determines if the geometry of the picture is straight---red and blue are adjusted to it---to align the green you need to call the convergence mode up and then cover the lens for the red and blue---leaves you with a green grid---then you need to select green and wherever the grid is not straight adjust it--once you get it straight you need to uncover the red and adjust it to the green, and then the blue to the green---green alignment determines if the picture is straight---It sounds like this guy did not try to get the green straight and just adjusted the red and blue to whatever the green was.
My point here is if you paid money for this repair--either he aligns it straight or you should get your money back----GREEN never needs to be adjusted unless the dcu(digital convergence unit that stores the adjustments) has been replaced or the Convergence module has been replaced---I bet if the original convergence module was repaired(chips replaced etc) and installed you would not have this problem.
If the guy replaced the DCU then GREEN must be fully adjusted for a straight picture FIRST! then red and blue adjusted to it.
It is not easy or quick to Adjust the green--maybe he just wanted to get out the door?
I do this here for free so if this has helped you take a minute and give me a vote here.
If you have any questions or need help reply to this post here.
SD TECH
Sep 05, 2009 | Samsung PCL6215R 62" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Hitachi 43fdx15b
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced. It could set you back between $200-$400, depending upon how many components need replacing.
You can also try a hard reset..Unplug all cables, including power from the back of TV. Wait for 4 hrs and reconnect them. Try and see if it works now.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Feb 05, 2008 | Hitachi 43FDX15B 43" Rear Projection...
Green picture
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Still green
go In service convergence mode and try to adjust red and green if you cant then it's convergance amp ic's
if you can adjust them so they align up try doing a touch fous after that,.
Dec 16, 2007 | Toshiba 42H81 42" Rear Projection...
Picture has a green outline
your convergence ic's and possible low ohmage reisistors are at fault.there the large ic's that start with stk
Sep 10, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
