Question about Whirlpool LER4634J Electric Dryer
Whirlpool elec dryer
Intermittant heat.sometimes it gets hot for a short time but never stays hot thru entire cycle.i replaced element same prob. vent and ducting are clear
    Sergeant:
    Champion:
  • 324 Answers
Check your lint filter, take it to the sink and see if it holds water. it may be clogged from using fabric softner in youe washer.
Posted on Nov 11, 2008
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Whirlpool dryer overhead I change termo fuse all the thermostat but is still overhead is cabrio steamer dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
May 03, 2015 | Whirlpool Dryers
My Whirlpool duet electric dryer seems to get too hot and stops working
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 12, 2014 | Dryers
My Amana Tandem 7300 electric dryer will not stay
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 27, 2014 | Dryers
My whirlpool duet dryer will dry one load of
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 14, 2014 | Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Aug 09, 2014 | Whirlpool Dryers
Dryer keeps shutting off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 18, 2014 | Whirlpool Duet GHW9150P Front Load Washer
It is taking too long to dry the clothes. Have to run 2 to 3 cycles
Could be several things a short cycling thermostat not allowing heating element to stay on for the correct amount of time,or a restriction in the exhaust vent system.The second issue is easy to check,start unit go to outside to the dryer exhaust vent it should have plenty of warn air exiting vent. if not you will have to clean entire system out not just the hose behind unit... Hope this helps
Aug 10, 2010 | Whirlpool LER4634J Electric Dryer
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
Dryer gets to hot
Start with the vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If the vent is ok, turn the timer to any on position without starting it. Wait 10-20 seconds and then check if there's heat inside the dryer.
If yes, the element has a short and therefore always stays on. Replace it.
If no, run the dryer for a few minutes and listen for the clicking of the relay which cycles the element.
If there is no clicking sound, check the hi limit thermostat & thermal cutoff for continuity and replace if necessary.
If those seem ok, it could be the motor (centrifugal switch inside) or the timer (shorted contact).
If not
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
