Error 1300 keeps coming up on myh Canon Pixma IP4000 although there's no paper?
    Guru:
  • 183 Answers
Dear pants53,
Code 1300 indicates that paper jam error occurs. First, check whether any broken paper inside the paper path, remove it then press Resume/Cancel button. If problem still persist, means paper sensor error or paper sensor cam is broken. If it so, then I suggest you bring your printer to nearest service center.
Regards,
Posted on Nov 08, 2008
Paper Jam error 1300, but no paper jam!
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 20, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I have a PIXMA iP4000 - won't print-says no paper, load and resume- printer has paper but low black catridge -is it related to no paper problem
I have seen - with canon printers - where a low ink cartridge did result in a 'load paper' error. It is not uncommon.
Feb 10, 2010 | Canon PIXMA iP4000R InkJet Printer
I am receiving "Service Error 6A00" in print log when using my Canon PIXMA iP4000 Printer
That error means either a paper scrap is blocking the cleaning assembly on the right where the printhead parks, or the gears are worn out in that assembly. It's called a purge unit and runs around $30.00.
Dec 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon iP 1300 keeps coming up with Paper Jam
this problem may be due to many reason.
first due to moisture in paper. try some good one and rey paper.
second due to dirty paper feed roller problem. clean the roller with moist cotton using cleaning liquid such as spirit, petrol or nail polish remover.
and last may be due to mis allignment of paper feeder assembly contact any printer specialist.
Aug 21, 2009 | Canon PIXMA iP1300 Printer
IP4000 service error 6B00
6B00 is a paper feed error, look in the back with a mirror and flashlight, and see if something has fallen in where you put the paper for printing.
Jul 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My Canon printer ip4000 power button keep flashing 1 green & 5 yellow flashes. What is wrong ?
It may indicate a printhead error. Look at the followng instructions at the Canon website:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
Apr 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma ip5000
I had identical prob with a PIXMA IP4000. Eventually solved by turning upside down removing bottom feeder tray and gaining access to the four rubber rollers which pick up the paper. I rubbed each one with light sandpaper to roughen up the rubber, turning each one by hand trying to try to abrade all the surface. It did the trick.
Oct 03, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
765 people viewed this question
k24674
jasbo
jasbo
