Question about Minolta Di151F All-In-One Laser Printer
Minolta Di 151
Trying to print but getting Message "Service Call c0500" Is this something that we can fix ourselves? Thank you, Kelsey Mitchell
  • Minolta Master
  • 6,825 Answers
How to clear a C-0500 error code.SolutionHold down the [Clear/Stop] key while turning on the power.
For the Di151f, hold down the [0] key while turning on the power.
if the code comes back replace the fuser unit. DO not continue to reset the fuser can catch on fire and that will ruin a perfectly good day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 26, 2015
5 Suggested Answers
chibibarako
  • 7 Answers
SOURCE: minolta di 151
You're going to have a tough time finding a paper manual, since Minolta was bought out by Konica. However, if you have Adobe or another PDF reader you can get the manual on the Konica-Minolta website: DI151 Fax Manual
Posted on Oct 24, 2008
SOURCE: minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: minolta di 151 has a problem coping properly, need to know why, replaced toner and still has problem, need either manual or what else could be wrong...
If the printing is poor and almost white copy, you need to replace the developer in the image unit, clean all the lens first to be crystal clear.
Posted on Feb 19, 2010
Daniel S
  • 4323 Answers
SOURCE: Problem on Minolta DIALTA DI
Hi
Error code C070 or C0070 is related to toner not seated properly. Power off the machine and gentlly take out the toner bottle. Turn on the machine without the toner bottle, let the machine go through its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
C0500 means Heating Roller warm-up failure. Open and close the right side door. There's a switch hidden under the frontcover activated by the side door. Sometimes the grey plastic arm attached to the sidedoor is not actuating that switch properly.
To reset the error Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter "3" from the 10-Key Pad when dot appears at the center on the left side of the screen while the start-up screen is being displayed. (Enter code 0000) You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or thermistor. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
Minolta DI-151 trouble code c0500
Sir/Mam Power off the machine. Wait ten seconds then holding down the Stop/Cancel button power on the machine. Clear the code then power off the machine. Wait 10 seconds and power on. If the code comes back you need to look for a new fusing unit (Hot Part) DO not reset the fuser cold catch on fire. That would ruin a perfectly good day!:).
Jan 19, 2015 | Minolta Office Equipment & Supplies
C1300 in minolta di 151
Motor in the print head is out have to replace entire print head. Last I looked the print head was no longer available. Plus an hour or two work Time two get a new copier.
Feb 15, 2013 | Office Equipment & Supplies
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Dialta, Minolta Di 151, older version
hope you have only windows 95 or maybe xp at best
try this
Self Help Product Support Konica Minolta Business Solutions Inc
Oct 07, 2009 | Minolta Di151 All-In-One Laser Printer
Minolta di 151 has a problem coping properly, need to know why, replaced toner and still has problem, need either manual or what else could be wrong...
May 26, 2009 | Minolta Di151 All-In-One Laser Printer
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Konica-Minolta DI-2510F Displays code C0500
Solution:
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.{IT A SMAL HOLE THE SIZE OF PAPER CLIP IN DIAM-U CAN USE PAPER CLIP
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
GOOD LUCK
Dec 05, 2008 | Office Equipment & Supplies
Minolta di 151
Oct 24, 2008 | Minolta Di151 All-In-One Laser Printer
Minolta di 2510 code c0500
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Error Message on Start up
Avery ld machine try buying one on line and replace the main board achip or up grade
Jan 28, 2008 | Minolta Di151F All-In-One Laser Printer
Minolta Di151F All-In-One Laser Printer Logo
138 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
