Question about Car Audio & Video
Trying to install blaupunkt cdc2 with ccr 600 and i am having problems. how do i enter cd changer code cd display says cd safe
Benimur
  • 6966 Answers
SOURCE: I have a peugeot 207cc
I would venture that the main B+ wire of the Blaupunkt CD Changer is not connected to an always on B+12 such as the positive terminal of the battery. This wire is responsible for memory/location/track last play retention. The other B+ of the CD Changer is the remote trigger on which is fed by and from the head unit. This in effect makes the unit operate with two (2) B+,an always on and a triggered on.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
SOURCE: BLAUPUNKT 6-disc changer model #CDC-RF6ir
turn the unit upside down ... really ... try it mine is doing the same thing hope it helps
Posted on Jul 21, 2008
ginko
  • 19396 Answers
SOURCE: Need to know pinouts for
Provide model for your Blaupunt thanks.
Posted on Jul 31, 2008
JigSaw007
  • 157 Answers
SOURCE: my blaupunkt cd changer on
maybe youvr set it up to loop on one song
Posted on Aug 30, 2008
drifterK
  • 4924 Answers
SOURCE: Have Blaupunkt Cd changer attached
turn it on after turning on the motor ...and press the AS(or turn on cd player pressing this button on ) and hold to enter the code..or ..if you are already at that part the trick is that it has only 4 number buttons ..so each button is assigned to one digit in the code..
ex for the first digit ..press the number one as many times as the digit is ..
to type 2468 for example press no 1 for 2 times..the no 2 for 4 times ..and so on ..
each time you press a position it will be the number needed in that position ...
I hope I didnt made a mess with your senses....
Posted on Feb 12, 2011
Can you provide me the code for BLAUPUNKT IDC A-09 BP915034455060 7 607 769 150 prod NR fiat : 735 273 184
CODE 5731
Code Entry as Follows:
If Required, Enter Code in Head Unit First.
Press And Hold " CD.C" Button
The Display Shows "CD Player" Then "0000"
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Tuning Up Button " ^ " To Enter
Nov 25, 2014 | Blaupunkt IDC-A09 5 Disc In-Dash CD...
HELP I NEED CODE FOR BLAUPUNKT CD RADIO SERIAL NO IS BP8551W0944298
The only way to get a code is thru a Dealer. If it's an aftermarket unit, look for a Car Audio shop that sells Blaupunkt. If it's Factory, the Car Dealership service dept can get it for you. Be aware though, they will charge a nominal fee to do this. So when you get the code, put it in a safe place! If it's Factory installed and you are the original owner, It would have been with your owners paperwork. If not, call your selling dealer and they may get it for you at N/C. Hope this helps.
Jun 01, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
I have the Blaupunkt IDC A09 5 stack cd-changer. How and where do I enter the 4 numbers of the code and , finally, how do I confirm the code, which button should I press after the code ?
Blaupunkt IDC A09 Code Entry
On the head unit press the [ CD .C ] button.
The display will show 'CD PLAYER' followed by ' 0 0 0 0'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ station ^ ] button to save.
Apr 01, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
I now have the code for my radio but no manual to show how to put it in. Its a Philips CCR 600 in a Vauxhall Vectra (B) 1998 The Radio Screen is showeing 7 SAFE ! what dose this mean !
7 SAFE means wrong codes have been entered previously
To restore leave SWITCHED ON ...UNDISTURBED until it has automatically reset itself
This may take an hour or more
Vauxhall CCR 600 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
Feb 14, 2011 | Philips Car Audio & Video
I have the unlock code for my phillips cr600 car radio and cd changer but dont know how to enter the code can any one help please
CCR 600 Code Entry
Jul 10, 2010 | Philips Car Audio & Video
How do I enter the radio pin code (which I have) for a 2001 Holden Vectra JS Series? The radio is a BLAUPUNKT factory standard model.
press and hold AS button for a couple of seconds till beep is heard and CODE----
is displayed in the display
use the preset button 1to get 1st number then preset button 2 to get second number etc.... until all 4 digits are entered then press and hold AS button again until beep and radio should start working
Oct 31, 2009 | Blaupunkt Car Audio & Video
My blaupunkt car 300(d) stereo say 7 safe.how do i remove this problem so i can enter my code?
It says 7 SAFE because wrong codes have been entered so make sure you have the correct code..
To reset press ON button & AS Button at the same time and leave SWITCHED ON ....UNDISTURBED for an hour or two and it should reset itself automatically
Oct 11, 2009 | Blaupunkt Car Audio & Video
IDC A09 installed in Fiat Punto
After incorrectly entering the code 3 times, the unit locks for 60 minutes. To clear it, leave it connected to the head unit and the radio switched on for an hour. After that, switch the radio off, disconnect and reconnect the cd changer, and enter the correct code.
Jun 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
