You will find the diesel pump at the petrol station have slim nozzles that release the safety feature and the other petrol types a wider nozzle thus preventing you from putting the incorrect fuel in your tank. Your spare tyre compartment should contain a special funnel to use that releases the safety catch for you to fill from a can.
SOURCE: what oil should i use for ford mondeo turbo diesel
5 litres of Ford SAE 5w -30w (Formula E ) ...available from Ford (or sometimes a lot cheaper off Ebay).
If you try and use anything else,( eg 10w-30 etc) then the turbo does not like it and the running becomes slightly sluggish
Testimonial: "Thank you very much, this information was 100% i will ce4rtainly use again"
SOURCE: my fuel gauge doesnt work on my 2001 ford mondeo
Check your fuses. If thats ok, you probably have a broken wire on your sending unit which is located on top of the gas tank or your sending unit is bad and will need to be replaced.
SOURCE: where is the fuel sender unit on a s reg diesel
In the tank wiyh the pump as one....Hope this helps.
