Question about Sony SLV-ED40 VHS VCR
70084 my vcr getting off and this code appear on lcd :70084 model ed40
Stop when playback and fast forward and rewind, and display"31286
I don't have the specific manual for your model, but typically this symptom is an indication that the movement sensors have a problem. These units are designed to detect movement of each of hte hubs (tape actually) and to shutdown if either are not "moving". This is to prevent the tape from getting damaged. Improper tape loading (the machine loading not your insertion of the tape) can cuase this. This usually can be fixed without parts. The unit needs a good cleaning and alignment check. Please take this to a repair shop. I estimate a $50-$75 charge for this repair.
Dan
Mar 05, 2011 | Sony SLV-ED40 VHS VCR
Why will my VCR not work with my LG LCD TV,model 47LD520?IT comes on but will not play tape.
The tv LCD screen panel reconize the VCR and have the LCD screen panel,have a LCD have a blue screen wright,that incated u hook up the VCR wright.The VCR is not playing the tape,because is the VCR have problems,Not the tv itself.
Oct 26, 2010 | LG 47LD520 47 in. HD-Ready LCD TV
Remote control gives wrong signals
You should goggle the model number and check if they have supplied you with the correct remote control.
Nov 04, 2017 | Sony SLV-ED40 VHS VCR
No image in either viewfinder or lcd
CCD Imager in your camera id bad and needs to be replaced. Follow the Sony web link for details.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
Sony offers various models repair with CCD Imager issue free of cost but I couldn't find your model in that list. Contact nearest Sony Service Center for guide lines.
Jun 26, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Need code for a Durabrand on urc3605 one for all remote.
Durabrand TV/VCR Combo=0153,0245
TV/DVD COMBO=0153,0405
DVD/VCR COMBO=0405,0245
HOMETHEATRE =0449,0405
PLASMA/LCD= 0189,0135,0157,0153,0254,0458,0217
VCR=0245
Apr 27, 2008 | One For All URC-3605 Remote Control
VCR Error
If u dont have a remote for these, it is just the programming setup, i have same prob, but because I dont have a remote I cant get past it
Apr 26, 2008 | Televison & Video
Sony Slv-EZ10 Error
try unpluging it for a day
good luck
please mark the post with a fixya!
Feb 04, 2008 | Televison & Video
Tuning a Funai 31B-250 VCR to a Wharfedale L22T11W-A LCD TV
i have a wharfdale L22T11W-A LCD TV. have got sound but no picture, any ideas?
Dec 22, 2007 | Televison & Video
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony SLV-ED40 VHS VCR Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
