Question about HP ScanJet 3500C Flatbed Scanner
Power requirements My 9 voltAC supply failed. Can I use a 15 V 3 amp instead?
    President:
  • HP Master
  • 1,314 Answers
NO....if you do you will burn it up. You must use a 9 V adapter.
Thanks and please take a moment to rate as fixya.
Posted on Nov 08, 2008
Why my hp designjet 500 smps has high voltage than normal
check power supply and if voltage are good change Electronic module its damaged. this voltage what you are write not normal!
May 21, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Hi I have a car amp in my room which is hooked up
Car amplifiers cannot be powered by laptop power supply. These amplifiers have different power ratings. You need to check the Car amplifiers power requirements / rating (Voltage & Current requirements) and then get a power supply with the exact same Power ratings. If the power supplied to the amplifier is less than the rated power it needs, it will not be able to drive the amplifier IC's and transistors in the amplifier and will not produce good sound.
Please check the power requirements for the amplifier and buy a suitable external power supply for it.
Sep 01, 2014 | Computers & Internet
Voltage change to 120V
You can change the plug out but I very much doubt that your toaster will even heat. The way toasters work is by a resistance wire that heats up because of the current going through it that causes the wire to heat up. Since the wire that is in your toaster is designed to heat up under 220V drawing 9 amps. SInce you are now supplying only 120V then since I=V/R then in the first instance 9=220/R or 9*R=220 =24.444 Ohms Since in the second instance your V=120 then your Current =4.9 Amps and this will not be enough wattage to heat up the wires.
Jul 14, 2013 | Morphy Richards Accents 44744 4 Slice...
Ampage for 9-volt alesis sr-16 drum machine adapter
Here is a link to a discussion about this that will help:http://www.soundonsound.com/forum/showflat.php?Cat=&Number=679914&Main=679565 A 9 volt A.C. 3.2 amp power supply should work for you. Just remember A.C. not D.C. is required.
Dec 10, 2010 | Alesis Sr 16 Stereo Drum Machine
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How can i repair a power suply
9 times outa ten there is a small 2.5 amp fuse inside.
you will have to desolder it and er-solder a new one in.
Oct 07, 2010 | RaidMax 350W Power Supply...
My amp shuts down after about 15 mins then starts clicking all lights go out but still power on i have to switch off then wait and switch on again line6 spider3 120watt
The problem here is likely with the reulators on the power supply. Overheating is causing failure. Replace +15 and -15volt regulators as required
Secondary problem may be with the AMP IC itself. Check to make sure it is not overheating during operation by using a temperature probe. Check to make sure airflow is constant.
Do not electrocute yourself and/or fry the amp any worse than it is.
May 31, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
20-Volt DC Power Supply instead of 12-Volt amp
Here's a few things that come to mind. An auto charging system will operate normally from about 11 Volts to about 14.5 Volts, depending on what is operating (lights, blower,etc), and whether the vehicle is at idle or not. Most car amps will operate from about 10.5 to 16.5 Volts, and outside that range, they will probably shut down.
Another consideration is your 20 volt power supply. You didn't mention if it is a DC power supply, but it needs to be. The other factor is its output, meaning its amperage rating. I'm figuring it will need to put about 5 amps, at the least, for the Sony to put out some watts. I think the line fuses of the Sony are rated @ 25 amps each.
I don't like this type of situation, because I want to say 'try it and see what happens" and I want to say 'don't do it, something may blow".
If you decide to try the 20Volt power supply, maybe if you put smaller rated fuses (say 10 amp) in the Sony amp, they will act as a fail safe. Good luck!
Jul 26, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Mar 05, 2009 | Westinghouse SK-19H210S Television
HP ScanJet 3500C Flatbed Scanner Logo
87 people viewed this question
Seeker5211
Seeker5211
