Question about HP Pavilion zd8000 Notebook
When typing in password on Primary HD on boot up..skips two spaces at a time
This is an HP dv8000. When my husband boots up and tries to enter his hard drive password, it's entering two spaces at a time (double spacing). We have rebooted, unplugged cables, etc. Can anyone help please?
  • mzalanwrench Dec 31, 2008
    YES...we were able to resolve by taking the Hibernate/Powersave Mode and shutting it OFF. That we believe was the "cause". We also pulled out the CMOS battery and let it sit out for about 10 minutes. Once we put it back in, that seemed to clear it up. He did have to F1 and reset the clock in the bio set up. It's been working fine ever since. It just goes to Screen Saver now and not the Hibernate/Powersave Mode. Hope this helps...strange as it was...it's working now. Thank you!
  • Steve Allison
    Steve Allison May 11, 2010
    It's a little late to ask, you've probably solved the problem by now but -
    I assume you have tried backspacing over the double spaces?
    If you have solved the darned ting, post back what you found; I haven't heard of this one before but someone else might benefit from your gained knowledge.
  • HP Master
  • 5,568 Answers
Thanks for answering my request to post your findings back here.
For future reference, there is normally a jumper set close to the CMOS backup battery comprised of three pins. If so equipped, two of the three pins will have a jumper on them with the third empty. Resetting the CMOS memory is accomplished by switching that jumper temporarily to the other two, that would be center pin and the normally free one, this takes the battery out of circuit without physically removing it and shorts the CMOS voltage pin to ground to drain off any existing charge and resetting it.
Happy New Year for your family!
Posted on Dec 31, 2008
Reset bios password
Go to command prompt
Or
Press and hold window key and press "R" key
Type:- cmd and Enter
Type:- debug and Enter
Type:- o(not zero) space 70 space 2e and Enter
Type:- o(not zero) space 71 space ff and Enter
Type:- Q and Enter
Restart your computer and check Bios password should be removed
You can use hiren boot 15.2 software and can be easily download
May 11, 2013 | Toshiba Satellite M115-S3094 Notebook
Need BIOS password to enable boot from CD
Or
Type CMD and Enter
Type debug and Enter
Type o(not zero) space 70 space 2E and press Enter.
Type o(not zero) space 71 space ff and press Enter.
Type q and press Enter.
Now restart your computer
May 06, 2013 | Computers & Internet
Windows xp will not boot on my hp mini 110.Keeps flashing to start up screen
Try selecting Last Known Good Configuration, or Safe Mode, and use System Restore option to go back to a date where the system booted correctly.
If neither of these options work, then you need to try to get into Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. If you are prompted to Boot from CD, you need to change your Boot menu Order in BIOS or Setup to boot from CD before it boots from Hard Disk.
  3. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  4. Type 1 to select C:\Windows
  5. When you are prompted, type the Administrator password. (usually blank, so just hit the Enter button on your keyboard.
  6. Type chkdsk /r (space between k and /) and press Enter.
  7. The process may seem to take a while and freeze at times, but it's working. Just allow it to finish on it's own. Once done, you can type exit, and press Enter. Remove the CD before the system starts up again.
Jan 15, 2010 | HP Pavilion 110-1030NR Notebook
HP Pavillion dv8000--blue screens on boot up
Try this for a fix....
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
If the above does not work....you can remove the hard drive, get an EIDE / SATA to USB adapter, attach the adapter to the hard drive and plug the usb end of the cable to another computer. The computer will read it as an external hard drive and you can then get all your files that you need.
Nov 03, 2009 | Office Equipment & Supplies
I have a hp laptop with xp i updated it with microsoft update and the following day it started acting up. it is like the power switch his held in but sometimes it will run fine for a few minutes tried to...
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
C:\Windows>
cd \
C:\>
CHKDSK /R
Hit the enter key.
FIXBOOT
Hit the enter key.
Oct 17, 2009 | HP Pavillion DV1133WM Notebook
When I boot my computer the message "unsupported format" shows on the screen, then it goes blank. This started happening after I was reinstalling Windows XP and the process got interupted.
C:\Windows>
cd \
C:\>
CHKDSK /R
Hit the enter key.
FIXBOOT
Hit the enter key.
Oct 13, 2009 | HP Pavilion ze2000 Notebook
My compaq presario f700 has difficulty booting up. I typically have to do a hard stop 3 times before it will boot. It also freezes up returning from sleep mode
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
C:\Windows>
cd \
C:\>
CHKDSK /R
Hit the enter key.
FIXBOOT
Hit the enter key.
Oct 07, 2009 | Compaq Presario 700 470024-192 Notebook
Got bsod and now it doesn't read any os on hd,tries to boot and goes to ethernet to boot,is my hd corrupted and is it savable
C:\Windows>
cd \
C:\>
CHKDSK /R
Hit the enter key.
FIXBOOT
Hit the enter key.
Oct 07, 2009 | Toshiba Satellite A135-S4527 Notebook
How do I reset the computer, the password is lost
What if u don't know the password of your admin and still want to hack and change .. yea u can do it ..in a very easy manner.. check this. just follow the steps.. this doesn't require u to know the admin password but still u can change it..
  1. type Guest as user id at windows login.
Start >> Run >> [type]cmd // this will open your command prompt
[type] net(space)user(press enter)
[type] net(space)user(space)[windowsloginid](space)*(press enter)
// for e.g. : net user George or whatever your account name you want to hack. *(press enter)
[type] new password (press enter) and retype it (press enter).. it will show u confirmation... // caution it wont show u the password u type.. but it still types.. the blinking pointer will b there at the same place.. but it still works..
// for e.g. : password changed successfully.
Apr 05, 2008 | E-Machines eMachines Desktop PC
HP dv8000
Your windows might be corrupt. If you have a windows xp cd, boot to it.
Press R for Recovery Console. It will take you to a command prompt screen. Press 1 to select the C: drive. It will ask for Administrator password. If there is any, enter it. If there is none, just press enter.
Next type in "chkdsk c: /r" and then press enter. Leave it to run through the processes and when it completes, type EXIT and press enter.
Now boot to hard drive and see if it will boot up. If it still doesn't boot, get back to me!
Thanks and good luck,
Lolita
Nov 07, 2007 | HP Pavilion dv8000z Notebook
HP Pavilion zd8000 Notebook Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
