Question about Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Remote don't work using any key,but the display on the recorder shows DR-2 can use controls on recorder. Can anyone help PLEASE.
  • 1 more comment
  • Anonymous Jan 03, 2008
    The romote doesn't work and 'DR-off' comes up on player screen.
  • mikeyt111 Mar 16, 2008
    I have a new Toshiba RD-85DTSB with the same problem. Only the volume works all other buttons cause DR2 to be displayed on the display.
  • Anonymous Jan 12, 2009
    Not Able to reset the remote, DR-2 is displayed
I generated the problem of a Toshiba RD-XS34SU/C by clicking SETUP then selecting Operational settings = DR 2. When I did this the remote would no longer do anything.
In the Toshiba HDD/DVD VIDEO RECORDER RD-XS34SU/C OWNER'S MANUAL INSTALLATION GUIDE page 46, 47 the indication is that the remote and DVDR are set to different codes.
If you want to set the remote to IR code DR 2 hold down the EASY NAV button while pressing the 2 button. This sets the control IR code to DR 2.
Don O
Posted on Feb 01, 2009
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Posted on Oct 24, 2006
I had the same problem. On my remote, there is a green button with a black star above it. I pressed this button along with the #2 button and everything went back to normal.
Posted on Feb 02, 2008
Press EASY NAV and NUMBER 1 simultaneously.You should here a beep. Don't change the IR setting when your in the system. You will loose control of your remote..
Posted on Jul 20, 2012
I have the same problem & tried that. It didn't work for me. Can you help?
Posted on Dec 03, 2007
I'm from iran. sorry for my English. I have a Toshiba DVD video recorder D-R4SC model. my remote control is not working. when I want use romote control it shows me DR-2 (or somthing like this) Error on tv....
Greetings,
Check pages 44 and 45 of the installation guide (not the owner's manual.) It will tell you how to change the recorder & the remote from DR 1 to DR 2 or DR 3. To change the remote you hold the * button plus 1,2 or 3 to change the remote.
Feb 13, 2011 | Toshiba Televison & Video
Front Display is saying DR-2 and will not let me use remote to control anything...only thing I can do is shut power off with front panel..I have unplug from outlet and let set for 30mins and plugged back...
I received an attachement from the Toshiba Repair folks several months ago, when we had the same problem. To resolve it, do the following:
While pressing the Easy Navi button on the remote, press 2. The remote control mode will be set to DR 2, which is what the recorder is telling you it is set to.
We encountered this problem for the first time, for no apparent reason. It happened again today, after the operator dropped the remote. This fix worked both times.
Nov 07, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Remote won't work-- Sylvania 19-in
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jun 02, 2017 | Sylvania 6427FF TV
Toshiba RD 85DT DVD recorder
ok you need to press STAR Button which says mode above it and either 1,2 or 3 to find which freqency is being use. The dvd and the remote need to be on the smae on.
Oct 18, 2008 | Toshiba RD-XS52 DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
I HAVE DVR RECORDER
i had the same problem. press enter, hold it down and press and hold 1 for about 10 seconds.
Jan 18, 2008 | Panasonic DMRES15 DVD Recorder
Remote control not working
Look into your manual that came with your dvd recorder for DMR-E80H, Page 46, Changing the Remote Control Code. My child played with a remote control as well and reconfigured it as well. In the manual, you have explanation how to configure your remote control again to work.
Nov 17, 2007 | Panasonic DMR-E80H DVD Recorder
Toshiba RD-XS34 DVD Player/HDD Recorder Logo
825 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
