Question about Kodak i40 Path-Through Scanner
Scaning documents Can anyone help Ihave to scan many documents, scaning faxes are not a problem but scaning letters that have been folded in envelopes are, scaner tends to pick up the folds in the paper as a result I have dark lines across the document which does not very look good. I thought it might need cleaning but faxes scan clearly so this can not be the case Thanks
  • 490 Answers
Try and alter the contrast settings. If the scanner does not pick up 'data' including folds, you'd blame it for non-performance!
S. Mohan. India
Posted on Mar 18, 2009
How do i send my application forms if they are on paper?
put in an envelope and put a postage stamp and address on the outside of the envelope and then put it in a post office mail box that collects mail to be posted.
If you were referring to email you need to scan the documents and save them to a file. Then you to email and compose an email message and click on the attach a file option and attach eack scanned page via its file name.
If you do not own a scanner
if the place you are sending the application forms has a fax then find out the fax number and then send each page via fax.
If you do not have a fax machine check with your local newsagency if they have a fax machine that you can send faxes on for a paid price.
Jan 30, 2015 | Health & Beauty
I cannot find a template using Microsoft Word - Envelopes & labels for Avery label #6873.
Try this:
  • On the tools menu, point to letters and mailings, and then click on mail merge
  • Under select document type, click envelopes the active document becomes the main document
  • Click Next: Starting document.
Aug 06, 2008 | Office Equipment & Supplies
Can you print address on envleope
Yes you can print an address on an envelope. Do you have Microsoft Office? If so, click on new office document and click the tab that says Letters & faxes (for versions before 2007) and choose the label wizard. When the window opens, click the tab that says envelope instead of label and follow the prompts to type in the information you want to print on yoru envelope.
If you have Office 2007 - or newer, click on new office document and then choose blank document. Click on the tab at the top that says mailings and then choose envelope and type in the information you want to print on your envelope. Then click on file, and print. You will need to load your envelopes in the printers tray and put them in the correct direction according to the settings your machine requires. You might need to waste a few envleopes until you get it right.
Oct 22, 2011 | HP Photosmart C5280 InkJet Printer
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Hi! My matchine is scaning all documents in Grayscale by def
yep!
sorry but our panasonic dp-8035 is only black&white document scanner.
Jan 14, 2010 | Panasonic DP-8035 Grayscale Copier
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Samsung scx 4100 printer Problems
hi i installed succesfully samsung scx-4100 printer drivers in my loptop, ihave window xp home in laptop, when i am scaning my document it says the "unknown devise name".when i am printing the document it work very good with out giving any problem . can you please suggest how i can solve this proble. thanks faruk memon
Apr 15, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Kodak i40 Path-Through Scanner Logo
128 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
