Question about Bunn NHB Coffee Maker
Bad tasting coffee
All of a sudden our coffee has a terrible taste. We ran vinegar through it, but that didn't help. Any suggestions?
    Novelist:
  • 125 Answers
Hello. Usually bad taste is one of 3 things, water quality, coffee quality is changed, or brew temp is different. Try removing all the water, by tilting the unit over the sink, unplug please, so the end where the funnel would go is draining the water into the sink, go slowly. Once all the water is removed, refill it with fresh water until it comes out the spray head/funnel area again, plug back in, heat and test. Now there could still be residue in the tank, and it may require doing this a couple of times to clear fully. Try another coffee, may have just had a bad can/bag/etc..
Last, take the temp of the water coming out of the funnel, should be about 180 deg. F, if not it could be too cool, and needs a thermostat or element. If you need a service provider, go to www.bunnomatic.com and locate a service near you.
Hope that helps, and thank you.
Posted on Apr 11, 2009
After two months the water that's boiled it still makes tea and coffee taste funny ?
What are you using for water? If you are just using tap water try buying a bottle of distilled water at the grocery store. Tap water - especially if it has Chlorine in it - makes terrible tasting coffee. Plus I'd suggest it's not good for you anyway.
You can also try the manufacturer's cleaning recommendation which typically involved running a water/vinegar mixture through the unit and then a couple of empty pots of plain water.
Last thing to check is to replace the water filter in the coffee maker if the model you have has one. Some higher end models do.
Good luck.
Mar 13, 2015 | Coffee Makers & Espresso Machines
Keurig bad taste
I had that bad Keurig taste/smell for the first few months I owned it and almost returned it, but then someone suggested I run vinegar (1/3) and water (2/3) through it as though it was time to clean it and flush with just water for 3 cycles (see instructions)... and it worked!!!
Feb 08, 2012 | Keurig Coffee Makers & Espresso Machines
How do you clean the coffee maker? My wife put vingar in it to clean and ran it through the coffee making process. Now...after running several cups of water through it we still have a vingar taste. ...
Lol! Your wife did the correct thing. (Hate to say it)Vinegar is acidic and eats away at all of the impurities that tap water leaves behind. To clear the vinegar, follow these instructions to a tee. Run one shot glass of bleach...yes bleach...through the unit. Follow this by two or three cycles of plain water. Your coffee will taste better than ever! And get this, bleach kills 99.999 percent of all bacteria known to man! Look it up! Hope this helps!
Jan 07, 2011 | Keurig Elite B40 Coffee Maker
I had a stick of butter laying on top of my bunn coffee pot and some butter leaked through the vents. the coffee tasted terrible so i cleaned it with vinegar and ran about 10 pots of clear water through...
Believe it or not I had a customer once that left 6 pounds of butter on top of one of our brewers. They had it cleaned up on the outside so it took me a while to figure out what had happened but I could taste the rancid oils.
We ran about 20 pots of just water through it... make sure you let it heat back up before each one. I think the only thing vinegar might help with would be lime/calcium build up so I wouldn't think it helps this particular situation.
Dec 21, 2010 | Bunn BT10B Coffee Maker
Coffee tastes stale even after cleaning
A few things you can do. Buy less pods at a time and store them in a jar. Shake or aerate the water when you put it in the unit. Don't put it in, the night before.
Jul 26, 2009 | Philips Senseo HD-7810 Coffee Maker
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee pot
durabrand has no contacts outside china this is a unit made for and imported for walmart only walmart is the only contact ...... your problem is not anything you or walmart can do anything about the problem is the cheap plastic that is used , when it gets hot some people can taste and smell it and others cant . .. its getting more common in everthing that heats water .. personaly i would not drink anything from an appliance that puts a plastic taste in my water ..... if you move up in price the problem is reduced , better plastics are used , but your not going to get one for 10.00 ! "you get what you pay for " more now than ever .... good luck Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 18, 2008 | RoadPro 12-Volt Coffee Maker
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Suddenly coffee tastes TERRIBLE!!!
First try putting a cycle through with no coffee - see if you have any more luck identifying the taste. If you haven't descaled recently, that could be the cause - scale can hold other materials which can be tasted - run a cycle with 50% white vinegar, then rinse through a couple of times and see what you get - if you need to get rid of any vinegar taste, just run a cycle with a couple of teaspoons of bicarbonate of soda through. The water could still be to blame - even purified, there are certain things that can change that most purifying methods will not remove, such as higher salt levels during summer months etc. Make a cup of coffee without the machine at all, and see if you get the same aftertaste. The machine may not be to blame. Hope this helps, please ask again if you need more info :)
Sep 09, 2007 | Cuisinart DGB-600 Coffee Maker
Bunn NHB Coffee Maker Logo
564 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
