Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Kenmore Self-cleaning Gas Range 665.75012
Since we bought this new back in 2002, we have had problems with the gas oven not wanting to stay lit for longer than 30 minutes. It makes a loud "poofing" noise when lighting (which to me is scary). After 30 minutes or so of being lit, it will then try to relight 3 times and then will lock out, cannot be restarted until oven has cooled. Not fun when you're trying to bake cookies, roast, etc. Any ideas as to what the probelm can be? We've had Sears here to look at it and they supposedly can't find a problem.
I have the same problem with the same exact model. Any helpful troubleshooting tips would be much appreciated. I'm not sure if this is a heat sensor problem or a problem with the control board.
Anyone have any ideas?
Posted on Jun 01, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Oven lock stays locked
Try unplugging the range and plugging it back in - that should reset the lock
Jun 17, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Beeping sound with a message dr
I have a kenmore elite range model#790.9802. the walls of the oven expanded after a self cleaning cycle that the rake fall. i want to take the oven cavity out and reshape it. the problem / anyone know how the oven cavity comes out? I don't want to break the oven by trying to remove it the wrong way.
Sep 23, 2013 | Kenmore 75844 / 75849 Gas Kitchen Range
I have a Kenmore gas range model # 7907578890. I pushed the clean button to clean the oven, door locked and cleaning started briefly then stopped. Door stayed locked. Now oven won't respond to any buttons...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 18, 2011 | Kenmore Ovens
I hit the select clean button on my kenmore gas self cleaning range by accident and now i cant cook on it
heatman101
Sep 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Kenmore Oven Problem I have a Kenmore 79012 Range. The burners and broiler work fine. The ignitor comes on in the oven, but it will not light. After a few minutes I can smell gas, but the ignitor is still...
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Jul 28, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Did self clean now oven does not work
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jul 16, 2009 | Kenmore 36665 / 36669 Gas Kitchen Range
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
199 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
