Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Engine cut out
When the blower is started, and the throttle is pushed, the blower automatically bogs down and shuts off. Ihas clean fuel and used carb cleaner to clean out the carb.
  • 1 more comment
  • dxbam Nov 09, 2008
    I have the same issue with my (new) Echo backpack blower.
    Starts OK and runs fine, but as soon as you apply some gas, it shuts off.
  • Anonymous Nov 12, 2008
    im having the same thing happen right now. maybe just needs a screw ajusted? i dont know cant find the one
  • gdmiller1 Nov 28, 2008
    I have the backpacker blower that does the same thing. I messed with the carb adjustments and did not pay attention to the original settings. Does anyone know what they are?
On the bottom of the carb. there is a plate held on by one screw, take that plate off and very lightly clean the screen on the carb with a bread tie wire, this worked very well for me. Mine runs great now:)
Posted on Sep 11, 2009
  • kensparks1 Sep 11, 2009
    Screw settings for the carbs are one turn out on each, hope this helps!
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
You still have problems in the carb highspeed circuit..some debris in the passages...
(be sure to watch the inlet valve seat, you can loose it and not even know it) Blow the carb clean in a box or something that will contain any part that may be expelled during cleaning.
Please take time to rate me
Mar 31, 2013 | Echo Garden
I have 2000 90hp Johnson. The engine starts fine, but after running at higher rpm if you shut it off let it sit approx 30 min it will restart but when you throttle up it bogs down and will not accept the...
Sounds like a fuel restriction. have you checked the fuel pump? Your carbs may also need to be cleaned, there are "circuits" and pathways in carbs that get clogged and need to be cleaned and rebuilt. when was the last time you checked the fuel pump or carbs?
Aug 18, 2010 | Boating
The atv starts with the choke on and idles great. When i go to throttle it bogs down and shuts off with an ocasional small backfire
you need to clean out the carburetor, the gas isn't getting through it. the bogging is caused by all the gas going into the engine cause of the choke, it dumps raw fuel into the engine and cant burn it all, there fore bogging and acting sluggish, the back firing is caused by the same thing, too much fuel going into the engine and being deposited in the pipe and igniting occasionally, clean the carb out and it will run fine
Feb 15, 2010 | kawasaki Full Suspension Mountain Bike Men
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
598 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
