Question about HP - HP Photosmart 8250 printer
HP 8250 Ink cartridges type 02 versus 363
I bought a HP 8250 in Belgium which apparently uses ink cartridges type 363. While in the States I bought an entire set of new ink cartridges for my 8250 not realizing that they were of the type 02.
Needless to say they do not work.
Is there anything I can do so that I can use these 02 cartridges ? Can I reset the chip somehow ?
  • 1 more comment
  • geirh62a Dec 02, 2008
    I have exacly the same problem
  • Anonymous Jan 18, 2009
    I bought my printer in the US and it works with 02 series but in France in doesn't work with 363. Any idea?
  • Anonymous May 16, 2009
    same problem
    Scholar:
  • 130 Answers
For that you need to call hp technical support. You may have to reprogram a rom chip or replace the main board, or some other parts.800-HP invent
or
800-474-6836
Posted on Nov 22, 2008
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
I HAVE AN HP PHOTOSMART C6280 ALL-IN-ONE PRINTER BROUGHT OVER FROM THE U.S.A. 3 OF THE INK CARTRIDGES ARE EMPTY AND I HAVE REPLACED THEM, BUT NOT WITH HP INK. THE MESSAGE ON THE SCREEN IS SAYING THE INK...
As the printer was bought in the US the printer is meant to use the #02 cartridges.
When you decided to replace the empty cartridges with refilled ones…the place you took them to be refilled more than likely decided to replace the little chip with a local flavour, which attempt to mimic original HP cartridges #363 (or what ever the number of those cartridges is where you are now). Hence now they are rejected by your printer.
But because the printer is only designed to use #02 cartridges it will reject every other cartridge/chip that do not have an #02 programmed into them….
You could try to call HP and explain them your situation and see if they can help you reset your printer to accept a different cartridge number …
Cheers.
Nov 08, 2009 | HP Office Equipment & Supplies
Ink cartridge from US incompatible with european printer
Yes that is how hp Manufactures its printers
you will not be able to use the cartridges of Different country
There is a Process called Reagionalisation after which you can use the cartriges ....
You need to get in touch with the HP TOTAL Care for the respective country and get this fixed or else you will not be able to use it
Nov 05, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink failure system error
1. Turn the printer off for few minutes then turn it back on
2. Clean ink cartridge
3. Update drivers
4. If nothing works, repace the battery
Sep 07, 2009 | HP Photosmart 8250 InkJet Printer
Printer set up to use ink cartridge 177. Need to change to 363.
Hello, I bought my printer from my home country to USA. The ink cartridege HP 177 is not available in USA and I tried HP 02 but it did not work with it.,....
How to find a solution for this problem.
Mar 02, 2009 | HP Photosmart 3310 Printer
Use HP 363 cartridges instead of 177 for my Photosmart C7183
Let me inform you that printer would be set as per the zone and here is the information regarding the cartridge details.
Zone 1
Zone 2
Zone 3
Zone 4
02
363
177
801
Regards,
Sagarjd
Nov 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Sep 12, 2008 | HP - HP Photosmart 8250 printer
Can't use my original ink # 363
Actually you cannot use your # 363 ink on your photosmart c6180. The ink is not compatible with the printer. Photosmart c6180 only uses HP02 vivera inks. And there is no way that you can reconfigure it because it is factory default. Unless you bought an HP02 ink from other country outside US and bought the printer in US, that's the only time that we can reconfigure the regionalization of the printer
Aug 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Wrong colour cartridges
Did you try the genuine HP cartridge? Maybe you should try first the original Ink Cartridge.
Nov 15, 2007 | HP Color LaserJet 4650DTN Printer
620 people viewed this question
Ben Johnson
