Question about Microwave Ovens
Remove wall mount microwave
Hello, I am having real difficulty removing the wall mount microwave. I have tried all possible ways but the thing will just not come out.
any suggestion would be great!!!
  • Anonymous Dec 07, 2008
    Frigidaire wall mounted microwave will not come down off the wall.
    Any ideas?
  • Microwave Ovens Master
  • 8,973 Answers
The installation instructions will tell you how it's attached.
Contact Danby Customer Service US / Canada
Posted on Nov 08, 2008
Tip
HOW TO REPLACE THE DOOR OF A MACROWAVE OVEN
GeneralElectric is internationally known as a premier manufacturer of ranges,ovens, stove-tops and various other household appliances. ConsumerReports ranks General Electric appliances high on functionality andtheir low rate of repair. Currently, manufactures microwave ovensand wall ovens. Microwave oven doors are designed to be removed andreplaced by professional repairmen because a "leak test" must beperformed upon replacement to ensure ions are not coming off themicrowave's magnetron. With wall oven doors, removal and replacement bythe owner is a straightforward task that is safe for any owner tocomplete.
Here are step by step Instruction on how to fix in your microwave door below.
step1.
If your microwave door is cracked or the latch is broken, you may be able to replace it instead of purchasing a new microwave. Check the manufacturer's website to find out how to order a replacement door that is compatible with your specific make and model or visit any technician store that deal with microwave and oven around your local area to get one.
step2
Your owner's manual may also list a part number, which you can use as a reference when looking for a new microwave door.
step3.
Difficulty or note able part : Moderately Easy Instructions material needed Replacement door with Screwdriver a technician tool .
step4.
Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket.
step5.
Open the door and take out the glass tray.Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
step6.
Ask someone to hold the microwave door as you disconnect it from the hinges.
NOTE:
Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door.
step7.
Remove and discard the old door. Have your assistant hold the replacement door up to the hinges.
step8.
Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass.
step9.
Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave.
step10.
Set the glass tray back inside the microwave and close the door.
Good luck.
Thank you and thanks for using visiting fixya.
on Oct 27, 2010 | Microwave Ovens
How to change fuse for lg lrm1250W
Hello
Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
Oct 05, 2011 | LG LRM1250 Microwave Oven
Was microwaving a hotdog on a paper plate covered by another paper plate and the microwave just kind of went poof and now nothing lites up (display) and it wont work. I checked the breaker it is on and...
Yes there is.
Unplug the MW.
Uninstall from wall mount (if installed that way.).
Remove outer cover by removing the screws at back and (possibly) bottom sides.
Locate fuse. Replace only with an equivalent type and amperage.
You can test the MW without reinstalling or putting the outer covering back on.
Dec 21, 2009 | Kenmore 63672 Convection/Microwave Oven
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do i take it down?
If possible, to make the job a LOT EASIER, pull the stove out from the wall, so you can get under the mocrowave.
DISCONNECT THE POWER.
You'll have to remove the unit from the case.
Remove the screws from the bottom and it should slide out. Then, remove the mounting screws. It's best to have a helper, it isn't always in a good position.
May 25, 2009 | Kenmore 63792 Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Dec 18, 2008 | Sharp R-1480 Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
262 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
