Question about Quinny Buzz Jogger
Back wheels I picked up my pushchair after callapsing to put away and the wheels (two back) fell off. I know that they are ment to come off to pack into the bag, but the problem is we cannot get them to clip back in. There is a grey button on the frame by each wheel that looks like it should click up or down when the wheel is pushed in and then pushed the opposite way to release wheel. When we push the wheel in nothing is happening and nothing is clicking. Can you help, Do you know what the problem is. Please help, as you know these pushchairs are alot of money and I really don't want to have to scrap it!!!. Many Thanks to you. Emma Smith
  • Emma Smith
    Emma Smith Oct 21, 2006
    Just to add that this pushchair is a Quinny Zapp and not the Buzz Jogger stroller. Sorry.
I tried wd-40, and jiggled the little grey button a bit and it finally loosened and then the wheel locked into place.
Posted on Dec 12, 2007
LOL, just got a Zapp, and didn't know the rear wheels came off at all (we've been using it for a week), so I had to go see if ours came off... Yes, they do come off, after you push a square grey button next to each wheel. Which then remains pushed in, and doesn't lock the wheels anymore! However, I did manage to re-lock the wheel by simply pulling the grey button back out with the wheel in place. I was able to grab it with my fingertips, but you could also use a needlenose pliers. Haven't fallen off yet! HTH.
Posted on Sep 29, 2007
Hi, I had similar. Actually if you release the black block underneath by unscrewing the lateral screw. Be careful as their is a spring underneath the black block. Having removed all of this, push the grey button up from underneath with the wheels push full on. This will lock them, THen keeping them pushed full on, replace the spring, black block and lateral screw. This worked for me. Seems bad as a work around but it does the trick.
Posted on Aug 31, 2007
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
I have a jane slalom pro my front wheel is driving me mad it is wobbling so much that my pram will not move forward sometimes, any help would be appreciated.
We have this problem with our powertwin when my toddler is not riding in the front and I only have the baby in the carseat at the back. There is not enough weight at the front to keep the front wheel firm on the ground. I solve the problem by switching the front wheel from swivel mode into locked mode whenever I only have the baby in the pushchair. But I switch it back as soon as my toddler gets in the front since its impossible to navigate with a fixed front wheel when the pushchair is fully loaded.
Nov 21, 2010 | Jane Powertwin Azulon Stroller
Right wheel fell off how do I put it back together need a schematic
if your wheel fell off there is no shematic that i know of however check to see if the studs are stripped if so pull the wheel ( POP-OFF THE BEARING CAP WITH A FLATHEAD SCREWDRIVER) unscrew thew wheel nut and pull the wheel (being careful not to drop the bearings on the ground ) then with an old nut or board (2 by 4) or something similar so you don't flare the stud so that it wont go through the hole. drive studs out and replace (fairly cheap). when you put the new studs in make sure that the teeth on the back of the hub line up with the teeth on the studs before you drive them in.if the whole fell off make sure that the threads on the spline (shaft) are not damaged. if so repair the threads and get new bearings . ( bearings only go in one way) and nut and cotter pin. (if you don't know that the race is any good take the hub to the auto parts store and ask the attendant at the counter) when reassembling do not over tighten the wheel nut and BE SURE TO PUT THE COTTER PIN IN AND BEND 1 PRONG BACK.
Sep 08, 2010 | 1987 Ford Ranger
Broken plastic part on Bebe Confort Street pushchair
the same happened to me - i spoke to another mom who had same problem and the shop she bought it from said it was manufacturing fault with some batches and replaced it even after 8months or so. I took mine back when my son was 6months old and they said the only ones they have heard of breaking was when people were picking the pushchair up and carrying it with that strap. not sure we have done that much although the instructions don't tell you not to as far as I am aware. the shop are sending it away to get it fixed for us though with no charge - just got to do without it for a week or two! so i would try taking it back...
Nov 19, 2009 | Baby Gear
I can't fix on the two large wheels onto my Hauck pushchair
Hi just bought the same and spent over 2 hours trying to fix the back wheels on as they just kept falling off. Just discovered the diagram is wrong, insert cap c the other way round, it takes a bit of pushing but once on the black small cap d snaps shut keeping the wheels on. Hope this helps
Sep 04, 2009 | Hauck Infinity Umbrella Stroller
I need back wheels for my hauck sprint 6 pushchair
if you go to a bike shop thay should be able to help
Jun 12, 2009 | Hauck Infinity Stroller
The rear wheel on my dyson dc01 has come off. i have been sent the real wheel fastner retaining pack but do not know what to do with the bits. There are two metal rings and two semi circular black rings....
There is a small groove in the end of the stud on the vacuum that the wheel fell off of.
Slide the wheel back on the stud, put the washer on then put the ends of the half clip in the grove on the stud pushing on the back of the clip with a small screwdriver on the clip to lock it back in the groove. The old parts may be still in the wheel if it rattles. There should be a plastic cap on the wheel like a little hubcap, pry it off with a screwdriver carefully so you can put it back on after the clip.
Please rate this solution if it helps you.. Thank You....
Nov 02, 2008 | Vacuums
Graco mosaic pushchair
yes you can get them on internet, hope this helps
Apr 28, 2008 | Baby Gear
Quinny Buzz Jogger Logo
225 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
