Question about Delta Luv Delta - Baby Products 5-in-1 Crib
How do I convert Jardine Crib 4 in 1 to toddler bed
The only sticker i can find regarding model type says PB 2005120991, although the print is faint, so I may be off a number.
Please help.
  • dgeisz Feb 14, 2009
    I need the instructions on how to lower the Jardine Americana mattress to the lowest setting, please.
If it the bed is named Americana 4-in-1 crib I have the instructions.
Posted on Jan 11, 2009
Where do I look to find a model and type number on a poulan chain saw?
The model number is typically the number on the side sticker of the saws pull start assembly....like 2150....etc.
Feb 20, 2015 | Poulan Garden
I need to know this nokia model number with no sticker left and a damaged power switch
My Nokia 6288 uses a PB-6m battery
Other Nokia phones that also use this model battery are -
Battery compatible with Nokia 3250, 3250 XpressMusic, 6151, 6233, 6234, 6280, 6288, 9300, 9300i, N73, N77, N93.
Feb 15, 2013 | Cell Phones
Please help me print round custom stickers. I use paper stickers to print them at home but the ink isn't compatible with the paper. What should I do?
What ink do you use? The right sticker paper will depend on the type of ink you're using. But if you want to spare yourself from all these troubles, I suggest just ask any online printing company to print stickers for you. Believe it or not, it's way cheaper and more practical.
Feb 27, 2012 | Office Equipment & Supplies
Where do you find the model no. of
Hi!!
May I know what type of computer do you have? Most likely for laptops it can be found on the bottom part of the laptop, for desktops at the back of the tower. It will be better if you will tell us what computer (Brand and type) do you have.
Thanks!
Jul 14, 2011 | Computers & Internet
I want know my pc serial number,my pc is hp pc pavillion dv6 ,on the screen
The serial number is under the laptop on a printed panel alongside or next to the model number.
Jan 11, 2011 | HP Computers & Internet
In my dorm room I have a N64, which works when I hooked it up. However it wont play in color it's only in black and white which is extremely annoying. I have a Sony Bravia. How do I fix this without...
You have more than likely connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables, COMPOSITE only uses one (the yellow plug). If you connect only one video cable to any of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check the connections on the rear of the TV and make sure you have not connected to a socket marked "COMPONENT", "Pr" "Pb" or "Y". If you are certain the cable is correctly connected, please try another cable.
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV. I will then be able to assist you further.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
I HAVE LOST IMEI NUMBER MY NOKIA N900
Hi.
You can get this number by typing *#06# on your phone.
Hope this helps.
Thank you!
Jan 09, 2011 | Cell Phones
Cant find the make and model number to program the sky remote to. even the manufacturer Konka doesn't have the model number of my tv....help!
Hi Dave,
I am also unable to tell you the model number of your TV. The make however is Konka as you have already stated. If you don't have a model number, the best thing to do is try generic codes Sky give for Konka.
0065 0584 0399 0742 0446 0246
If these codes don't work or you need instructions on programming your Sky remote, please post back for further assistance. Please include as many details of your TV as possible, e.g. Screen size, type (CRT / LCD / Plasma) and anything else about it's appearance that may help me to identify the model number. I also assume you have checked on the back of the TV - the model number is often printed there on a sticker.
Hope this helps - please post back if I can be of further assistance.
Regards,
BElectric
Dec 16, 2010 | Televison & Video
Printer prints faint labels
Hi. Thanks for your question
Print fainting could be caused by number of reasons. First think to check is ink roll. Replacing with new one would get this out of the way. If it still faints next thing I would do is once you opened the cover try and clean the print head and any visible rollers underneath the labels. Print heads can be cleaned with any alcohol solution. Best would be some kind of electronics cleaning solution. next thing to check would be labels themselves. It happened to me that labels where simply not very well finished and ink would not stick to them. Try roll of labels from other box you may have. If this all failed and your printer still faints labels that it never used to it could be the worse. Your print head may need replacing although this is very unusual for them to fail in this way.
I hope this helped you. Please don't hesitate to come back and ask more questions if this is needed. I've worked with thermal printers for 7 years now and I am sure we can find some solution to your problem.
Thanks for using FixYa
Dec 08, 2010 | Zebra Z6M Plus Thermal Label Printer
Printing number of copies problem
go to yor print menu.type the number of copies in that block that say number of copies .let me know if it did work
Apr 07, 2009 | HP LaserJet 1300 Printer
Delta Luv Delta - Baby Products 5-in-1 Crib Logo
1,073 people viewed this question
Top Delta Luv Baby Gear Experts
Dan
Level 1 Expert
Oloyede Monsuru
Are you a Delta Luv Baby Gear Expert? Answer questions, earn points and help others
