Question about IBM Lotus SmartSuite Millennium Edition 9.8 for PC
Will this run good with Windows Vista or will there be huge problems?
3 Suggested Answers
  • 17 Answers
SOURCE: How do I get a hyper-linked text or image to actually open in a new window when building my webpage?
USE this
<a href="Your">http://www.your-URL.com">Your Title</a>
<a href="http://www.your-URL.com"><img src="Path of image" />Your Title</a>
Posted on Aug 06, 2009
Testimonial: "Will try this out - Thanks!"
SpideRaY
  • 687 Answers
SOURCE: i want to remove my lotus smartsuite programme but
I good program to remove applications from your PC is jv16 Power Tools this is the free version it is up to 2009 version now but you have to pay for this.
Good for removing just about anything that doesn't have the uninstaller also removes registry entries.
Hope this helps please vote !!
Posted on Oct 16, 2009
Tauqeer
  • 496 Answers
SOURCE: I have Lotus Smart Suite,
I assume that you are using Windows as your Operating System. Please note that this error is caused when the Lotus 123 file become corrupt or the file becomes damaged. It is normal and can happen to anyone any time. I am sending you some links. From these links download the Lotus 123 file repair utilities or software. Please download them and try to repair your Lotus 123 files. Carefully download and install them and then work out. I am giving the links in order of my preference.
http://www.s2services.com/123-tools.htm
http://s2services.com/lotus123freeware.htm
Please note that the above two repair tools are free the following one in called " LotusNotesRecovery 1.0.0642" This tool is paid and I find it very remote that you might need it because it is used in terms of Data Base corruption. If you can access other Lotus 123 files in the same DB then definitely the downloaded tools from the above links will suffice your requirements.
http://www.freedownloadmanager.org/downloads/lotus-123-file-repair-43011.html
Good Luck!
Posted on Oct 13, 2010
Lotus 123 how to see the top row
try selecting upper left corner, which should select entire sheet, then unhide. Best guess, haven't used 123 in a while....
Aug 18, 2014 | Lotus Smartsuite 4 1-2-3 5.0 123 5 Wordpro...
I have ancient lotus 123, approach, amipro and need to fit them into the new lotus smartwuite. How
well an ancient is fine what is not fine is that xp you installed is most likely not compatible with older versions, which were 3.x and early xp ok
time for an upgrade methinks.
May 29, 2012 | IBM Lotus SmartSuite 9.8 Millennium...
I have Lotus SmartSuite 96 & Lotus Word Pro. For some reason the START button has moved itself from the bottom left to the top right of the screen. I have tried to drag it back (right click) but to...
First right click on the taskbar and make sure taskbar is not locked
then click on the taskbar and hold left button down and move it to the bottom
Thanks for using Fixya.
Please remember to vote for any solution that helps you out.
Dennis
Jul 01, 2011 | Lotus SmartSuite 96
Can I install versacheck platinum 2005 on windows 7
It only officaly supports Microsoft Windows 98, Microsoft Windows Millennium Edition (ME), Microsoft Windows NT, Microsoft Windows 2000, and Microsoft Windows XP. You can try running it on windows 7 in XP compatibility mode.
Mar 05, 2011 | G7 Productivity Systems VersaCheck...
Can't load on Windows XP home SP3 system.
The software is probably just too old for the system. I would suggest Jargon Naturally speaking as a replacement. It is a very good voice recognition product and not too expensive.
Feb 01, 2010 | IBM Via Voice PRO Millennium Edition 7.0...
I want to remove my lotus smartsuite programme but i didn't have the cd. how can i do ?
Oct 07, 2009 | IBM Lotus SmartSuite for PC
USE this
May 22, 2009 | IBM Lotus SmartSuite for PC
Please help uninstall
Try starting in Safe Mode and then uninstall it.
(press F8 during boot).
Jan 24, 2009 | IBM Lotus SmartSuite for PC
CPU reads 100%
your system is virus infected.scan your system with latest update antivirus.
Jan 05, 2009 | IBM Lotus SmartSuite Millennium Edition...
LOTUS 123
am a sales tax auditor in hospet i have purchased a new duol core desktop pc in that pc xp installed
but lotus does not support the xp os please give me solution
Jul 09, 2008 | IBM 1-2-3 Millennium Edition 9.5 for PC
IBM Lotus SmartSuite Millennium Edition 9.8 for PC Logo
63 people viewed this question
Top IBM Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Business and Productivity Software Expert? Answer questions, earn points and help others
